70cm band Antennas
christoph-tackChristoph Tack wrote 12/08/2020 at 20:20 • 6 min read • Like
General
Understanding Antenna Specifications and Operation : Application Note AN-00501
Antenna testing
VSWR measurements on quarter wave monopole antennas don't mean much in reality.  So the measurements below should be taken with a grain of salt.
The λ/4 monopole antenna performance strongly depends on the size and orientation of the ground plane and hand capacity etc...
An antenna with a good VSWR in a lab setup (using a large perpendicular ground plane) doesn't guarantee it will perform well in real life conditions, when it's connected to your HT.
Antenna tuning
  1. Monopole antennas must be used with a ground plane
  2. Use smith chart to find resonant frequency.  That will be where the graph crosses the horizontal axis.
  3. Tune the length of the elements to get the impedance at the resonant frequency closer to 50ohm.
  4. If antenna tuning is not possible (because of a COTS-antenna), you can use a matching network to match your radio's impedance  to the antenna impedance in an effort to get the VSWR < 2.0.
λ/4 Monopole antenna characteristics
AliExpress WirelessLink store PM433-ZB165BM (71A, 433MHz 16.5cm ZT SMA)
The characteristics have been measured with a direct connection to the VNA.  No ground plane added.  This will impact bandwidth as well as center frequency.
The default antenna frequency is by no means 433MHz, as can be seen in the first graph.
Wrong way of measuring ! : VSWR of antenna directly connected to VNA.(https://cdn.hackaday.io/images/5866921607457173224.png)
Monopole antennas should always be measured with a reasonable size ground plane (radius > lambda/4).
VSWR measurement of antenna on serving tray.  This seems pretty good!(https://cdn.hackaday.io/images/8070311607457349499.png)
Measurement on Smith chart with serving tray as gnd plane:
Measurement when SMA taped with Cu-tape to the edge of Al-GND plane (800x2000mm)
AliExpress WirelessLink store PM433-ZB165BM (71A, 433MHz 16.5cm ZT SMA) : manually shortened
Inexperienced as I am,I cut away a few centimeters to improve the impedance match in the 430MHz region.  The open end has been protected by double folding heat shrink tube over the end and then adding extra heat shrink tube over it.
VSWR measurement of shortened antenna, directly connected to VNA.(https://cdn.hackaday.io/images/7954321607457539146.png)
Of course, when measured with a ground plane, things look differently:
What I really should have done is leave the antenna as is and use an antenna tuning circuit to resonate the antenna at 434MHz.  A guide explaining this process well can be found here.
Super-Elastic Signal Stick
I didn't want to destroy this one.  It's made of Nitinol. As it's also a monopole, I measured it on the serving tray.  The serving tray has a hole in the center for a female SMA/female SMA adapter.  As this antenna has an SMA female connector, an extra SMA male/SMA male adapter was needed.  The SMA-cable is a 1m of RG-142.
Testing Ham Radio HT Antennas (Signal Stick, Nagoya, Diamond)
Yaesu FT-65E original antenna
Normal mode helical antenna
TTGO LoRa 32 433MHz antenna
I had been warned that this rubber ducky antenna with 40mm long plastic cover is not suited for tracking weather balloons.  When connected to the edge of a (800x2000mm) ground plane the antenna seemed to resonate at 466.8MHz, with the plastic cover removed the resonant frequency even went up to 504.4MHz.
Using this manual, we can replace the coil by a new one tuned to 404MHz, which will be more suited for tracking weather balloons.
I used 0.8mm enameled Cu-wire instead.  Starting with 30 windings and cutting them of one by one to tune them.  Remember to place back the plastic cap before measuring with the VNA, because the cap lowers the resonant frequency of the antenna about 20 to 25MHz.
Sleeve dipole antenna, aka bazooka
A balun near the antenna is definitely needed to reduce the effect of the environment on the antenna.  It will also make it easier to tune the antenna.
Flower pot antenna
Discone antenna
Wideband, suitable for scanning
Portable discone antenna
Folded dipole
todo
Links
Like
Rich text editor
