Raspberry Pi Pico & RP2040: Things You Should Know
uctronicsUCTRONICS wrote 01/24/2021 at 03:11 • • 4 min read • Like
Here’s everything you need to know about the new board and the RP2040 chip.
The official release video:
How much does the Raspberry Pi Pico cost?
The RPi foundation priced it at 4 US dollars (around £2.9)!
How much does the RP2040 chip cost?
We don’t know yet, but with mass production, we assume it can be as low as somewhere around half a buck.
Where can you get the Raspberry Pi Pico or RP2040?
Currently, none of the resellers are offering RP2040 chips, so you can’t buy it anywhere. According to the foundation, the RP2040 will be made broadly available in the second quarter of 2021.
As for the Pico board, rumor has it that none of those resellers have enough stock, if you buy from any of them, nine times out of ten you will be on backorder. And the estimated wait time? Weeks!
What UCTRONICS is offering
As the first one who brought the camera module to the Arduino platform, Arducam will make sure that all Pico fans will have cameras to play with by the time their board arrives.
And as Arducam’s first-class distributor, UCTRONICS will be listing their exclusive Pico camera series as soon as they come out! We have confirmed with Arducam that the ETA for their Pico camera will be within a month, stay tuned!
In fact, it’s not just Arducam’s cameras, we are also launching a series of sensors and displays along with a variety of other peripherals!
Specs of the RP2040 chip
It’s an effing beast! You can download the full datasheet here.
What does RP2040 stands for?
The RP2040 chip got its name from its specs, 2 for its two processor cores, 0 for M0+ (the type of core), 4 floors and 0 floors if no onboard nonvolatile storage.
Specs of Raspberry Pi Pico
The Pico board itself features a temperature sensor, clock, and timer,  the best thing about the Pico board is that you can program it in C, C++, or MicroPython.  Moreover, you can develop it with literally any of your computers running any operating systems.
Power consumptions of the Pico board
In sleep mode, it takes less than 2 mA / 0.006W.
While in full load, it takes around 90 mA / 0.33W.
It’s crazy low! How low is that? A small rechargeable battery with around 800 mAh capacity can keep the Pico up for weeks!
Raspberry Pi Foundation’s official explanation on microcontrollers
This vid should give you some clue about the chip on the Pico board.
Caroline Dunn’s brief sum-up and her demos
This will give you a little taste of what the Rpi Pico can do.
Jeff Geerling’s take on this new board
The in-depth review and his heartwarming temp-monitoring project will give you a thorough understanding of it.
Don’s straightforward impression toward the Pico board
His down-to-earth explanation will help you see where the board sits in the whole wide market.
Like
