IoT-devices LLC News and Updates
12/21/2022 at 21:45 • 0 commentsOn this page you will find news and changelog of our projects. This data is also available on our website and on GitHub or Twitter or AllMyLinks, but for convenience, we decided to post it here as well, so that everyone can read our news posts without leaving Hackaday.
Best Regards,
IoT-devices Team
26.02.2025
EN: Testing of energy consumption by Geiger counter GGreg20_V3
UA: Тестування споживання енергії лічильником Гейгера GGreg20_V3
Our company has conducted a thorough testing of the power consumption of the Geiger counter module GGreg20_V3, intended for use in DIY projects. The purpose of the study was to…
04.01.2025
EN: ESPHome firmware for ESP32 with GGreg20_V3 – solution to the problem with the pulse counter
UA: Прошивка ESPHome для ESP32 з GGreg20_V3 – вирішення проблеми з лічильником імпульсів
Problem solution - in the example for ESPHome firmware with ESP32 controller, the pulse counter stopped working...
21.10.2024
Note on the use of the DCDC_3V3_400V_V1 high voltage converter by the user to power the Geiger-Muller tube or in other DIY / IoT projects
21.10.2024
EN: Technical note on initial diagnostics of the GGreg20_V3 module with J305 tube
UA: Технічна нотатка з початкової діагностики модуля GGreg20_V3
Technical note on manual initial diagnostics of the GGreg20_V3 module with J305 tube to check the main module voltages at the control points and determine the module's operability
12.05.2024
Our site and the GGreg20_V3 DIY Geiger counter product are referenced by the author of the book Francesco Riggi, published by Springer in April 2024 under the title...
02.05.2024
EN: Etsy Star Seller status for two months in a row
UA: Статус Etsy Star Seller два місяці поспіль
We have good news! We are an Etsy Star Seller again!
For the second month in a row, our Etsy shop has received a Star Seller badge.![]()
24.03.2024
EN: Geiger tube J305 conversion factor: differences between the coefficient for source radiation power and absorbed dose. Technical note
We have previously written about how to calculate the coefficients for the SBM20 tube and the J305, tube that come with our Geiger counter module GGreg20_V3 for DIY / IoT…
8.01.2024
EN: Geiger tube J305: How to calculate the conversion factor of CPM to μSv/h. Technical note
UA: Трубка Гейгера J305: Як розрахувати коефіцієнт перетворення CPM у мкЗв/год....
Read more
