How to Edit Boot Config for Raspberry Pi 5 USB Boot: A Complete Guide
7 days ago • 0 commentsThe Raspberry Pi 5 brings a big leap in performance, connectivity, and flexibility compared with earlier models. One of the most useful features for advanced users is USB boot support, which allows the Raspberry Pi 5 to boot directly from a USB SSD or flash drive instead of relying only on a microSD card.
For many users, USB booting offers several advantages. SSDs are generally faster than SD cards, provide better durability, and are often more reliable for long-term projects such as home servers, media centers, development environments, or embedded systems. If you plan to run your Raspberry Pi 5 continuously or want better storage performance, booting from USB is a smart upgrade.
In this guide, we will walk through everything you need to know about editing the Raspberry Pi 5 boot configuration for USB boot. We will cover the prerequisites, firmware updates, how to edit the boot configuration, how to change the boot order, how to prepare a USB drive, and what to do if something goes wrong.
Whether you are a beginner setting up USB boot for the first time or an experienced maker looking for a clean reference, this article will help you get the job done.
Why Boot Raspberry Pi 5 from USB?
Before diving into configuration steps, it is worth understanding why USB booting matters.
Traditionally, Raspberry Pi devices boot from a microSD card. While SD cards are convenient and cheap, they are not always the best choice for performance or reliability. Over time, frequent read/write operations can wear them out, especially in workloads like:
- running databases
- hosting Docker containers
- using the Pi as a NAS or media server
- continuous logging or automation tasks
- compiling software regularly
By contrast, USB SSDs and even some high-quality USB flash drives often provide:
- faster boot times
- better read/write speeds
- improved system responsiveness
- greater durability
- larger storage capacity
On Raspberry Pi 5, USB boot is well supported, making it a practical and attractive option for many projects.
What You Need Before You Start
To configure USB boot on a Raspberry Pi 5, you should have the following:
- A Raspberry Pi 5
- A bootable USB drive, such as a USB SSD or USB flash drive
- A power supply, preferably the official Raspberry Pi power supply
- A microSD card, if you want to perform the initial setup from an SD-based Raspberry Pi OS installation
- A keyboard, monitor, and internet connection, or remote SSH access
It is also important to make sure your Raspberry Pi 5 is running the latest firmware and software updates before changing the boot configuration.
Step 1: Update the Raspberry Pi 5 Firmware and System
The first thing you should do is update your system. USB boot behavior depends partly on the bootloader firmware, so keeping everything current helps avoid compatibility issues.
Open a terminal on your Raspberry Pi and run:
sudo apt update sudo apt full-upgrade
Once the update is complete, reboot the system:
sudo reboot
Updating ensures you have the latest kernel, packages, and bootloader-related tools. This is especially important if your Raspberry Pi OS image was installed some time ago.
Step 2: Understand the Difference Between
config.txtand Bootloader SettingsA common point of confusion is the difference between the boot partition configuration file and the EEPROM bootloader configuration.
On Raspberry Pi systems, two different configuration areas affect booting:
1.
config.txtThis file is stored on the boot partition and controls hardware and startup behavior such as:
- display settings
- GPU memory
- overlays
- interface options
- device tree parameters
You can edit it with:
sudo nano /boot/config.txt
On some modern Raspberry Pi OS installations, the path may also appear as:
sudo nano /boot/firmware/config.txt
This file is important, but USB boot order is not primarily controlled here.
2. EEPROM Bootloader Configuration
... Read more
