[WORK JOB] - Ethernet Breakout PCB
10/09/2022 at 00:30 • 0 commentsEthernet breakout board for an esoteric piece of equipment with a very frustrating physical interface. Literally provides access to every single connection in the cable to simplify the hardware portion of the troubleshooting. Not very interesting schematic-wise and a very tedious layout process with regards to the controlled differential impedance on the Ethernet lines.
[WORK JOB] - Deployable Lab Power Supplies (Stock Image)
08/18/2022 at 13:44 • 0 commentsContained within a 9U deployable rack, these two commercial power supplies (1 rail at 1200W/50A/60V/1600VA and 4 rails shared at 420W/24A/70V/650VA) can be taken practically anywhere. In order to protect from voltage surges, these 'universal input' supplies are operated at 120V instead of 240V (via a rack mounted 2400VA 2:1 transformer), which massively increases input voltage headroom. This, combined with the inrush limiting resistor (with relay bypass) and over voltage suppression/disconnection, ensure that the deployable supplies are effectively bullet-proof and also free of start-up transients. Doing it this way also has the added benefit of a 120V output via NEMA 5-20R receptacles. Input to the box is 240V +10%/-15% at 50Hz.
[WORK JOB] - Basic Relay Box
05/02/2022 at 04:23 • 0 commentsAs basic and as fun as it comes, this box contains 3 relays that simply pass through power on three different voltage rails. Isolation is about 250V and the current rating is 10-15A depending on factors. Power by USB 5V and TTL signaled from a BNC, it's just a Denkovi PCB broken out to panel mount connectors. Looks pretty though (on the outside).
[WORK JOB] - Much Too Complex Constant Current Source
05/02/2022 at 04:16 • 0 commentsA miniaturised version of the complex current source, this PCB drives 0-500mA @0-6V with an optional high-speed digital modulation capability. There are a few fixes and a seriously modified approach to the control system, but it's basically just smaller and better (not that that was easy to achieve).
[WORK JOB] - Simple 60W Brick Power Supply Module
02/14/2022 at 06:07 • 0 comments![]()
Based on one of the standard Meanwell 1-Inch by 2-Inch 60W isolated power bricks, this PCB takes an 18-75V input and converts it into +/-12V voltage rails at 30W each. For this board there is no real care for the specifications of the brick itself, but what does matter is that it's simple and can be switched out easily to accommodate other voltage output levels. The filters are a combination of datasheet recommendations and other common parts.
[WORK JOB] - 3-Channel Laser Driver Hub
11/26/2021 at 22:12 • 0 comments![]()
Running off of 48V, this central hub for all your laser action contains 3x laser drivers, 5x TEC temperature controllers and 4x power supply DC-DC bricks with linearly regulated output stages added. Adjustable trim-pots and jumpers galore, it was designed with flexibility in mind and the two galvanically isolated regions of the board can also interact somewhat through an opto-coupler. Finally, one laser driver and one temperature controller can both each be modulated by external voltage signals that are mixed in with variable weighting. All of heat-dissipating components are placed on the bottom layer and mounted to a custom aluminium block (~80W worst case).
[WORK JOB] - 15W Isolated DC-DC Converter
09/18/2021 at 00:29 • 0 comments![]()
Based on the 5kV/20pF isolated TDK-Lamba PXG-M15 15W DC-DC module series, this board takes an input of 40-60V and converts it to a 15W, 5V/12V/15V regulated output. The voltage depends on 3 of the components loaded to the PCB (i.e. pre-selected). The outputs are regulated by 5 parallel LT3045 ultra-low noise linear regulators. These can be connected in either series or parallel.
[WORK JOB] - Multi-Voltage Isolated DC-DC Converters
09/02/2021 at 07:27 • 0 comments![]()
Based on the 5kV/20pF isolated TDK-Lamba PXG-M15 15W DC-DC modules series, this board takes an input of 40-60V and converts it to various isolated voltage sources. Select outputs feature the LT3045 & LT3094 ultra-low noise linear regulators.
[WORK JOB] - Complex Constant Current Source
09/02/2021 at 07:27 • 0 commentsEnhanced version of the basic current source, this PCB drives 0-500mA @0-6V with an optional high-speed digital modulation capability. Importantly, there is a monitoring capability provided with matched impedance. This thing still gets toasty!
[WORK JOB] - Basic Constant Current Source
09/02/2021 at 07:26 • 0 comments![]()
This PCB takes an analogue input voltage of 0-1V and drives an output current of 0-250mA through a load at 0-6V. Powered by a DC-DC brick, it uses an extra-ordinary current-feedback op amp for improved bandwidth. Heat is dissipated via the BNC!
[WORK JOB] - Super Capacitor Bank Evaluation PCBs
09/02/2021 at 07:25 • 0 comments![]()
Containing 12x 300F 2.85V supercapacitors each, these boards are used to evaluate capacitor impedances and characteristics. Each capacitor is charged from a separate isolated 1W DC-DC brick/linear combo with a 2-3V set point and 250mA CC limit.
Backyard 10-Circuit Water Utility System
09/02/2021 at 07:21 • 0 commentsSeparate from my automatic watering systems, these 10 water circuits
(controlled by switches) do the following: Fill/empty the turtle tank, clean
3 gutters, mist 4 things (2 fences, air-con & people), water the roof and
blast the lawn (fun!). -
[WORK JOB] - USB Connection Delay Stick
09/02/2021 at 07:21 • 0 commentsUsing only resistors, diodes and a capacitor to control a relay, this
module delays the pass-through of a USB device by 5 minutes. Some
devices simply REQUIRE that they be plugged in after windows has
booted! I WILL NO LONGER YIELD TO YOU. -
[WORK JOB] - Custom Lab Equipment Control Board
09/02/2021 at 07:21 • 0 commentsControls, powers & interfaces with various pieces of lab equipment.
Contains onboard processing, OLED, triple power converters, power
protection, buttons, buzzer. I/O is primarily terminal headers and BNC
connectors. The micro is the Teensy 4.0! -
USB-5V to 24V Super Capacitor Power Buffered Boost Converter
09/02/2021 at 07:20 • 0 commentsThis DC/DC converter takes 5V from the Teensy 3.6 USB supply and
converts it to a voltage of up to 24V. The balanced string of eight 50F/3V
capacitors (total: 1800J) allows for bursts of currents of 10A+ and very
simple/slow voltage regulation. -
Old Autonomous Ground Based Robots
09/02/2021 at 07:19 • 0 commentsAt uni I worked on multiple different ground-based object avoidance
robots for internal competitions. I usually did the electronics in the group.
See: -
First Class D Audio Amplifier
09/02/2021 at 07:18 • 0 commentsThis self-oscillating class-d audio amplifier was not my design. However,
what was special about it was that it was the first switching power
converter I ever constructed. This made it the defining project that
shaped the direction of my career. -
Very First Linear Power Supply
09/02/2021 at 07:18 • 0 commentsThis old thing had an output of +/-30V@3A and an auxiliary output of
+/-12V@1A. It basically powered the majority of my breadboard projects
early on (mostly audio related). It even had a variable speed fan
controlled by the heatsink temperature! -
Failed/Forgotten Projects
09/02/2021 at 07:17 • 0 commentsTo those projects that failed, frustrated or outright exploded; To the
projects that ended up being redundant duplicates, ultimately teaching
me nothing new... You won't be missed. Seen in picture: The 450 RC heli
that exploded in flight. RIP. -
RC Quadcopter with Video Downlink
09/02/2021 at 07:17 • 0 commentsAlthough there was no auto pilot, this old custom FPV quadcopter had
IMU based stabilisation, stupidly bright LEDs, some basic instrumentation
and a video downlink that made it quite enjoyable to fly around with the
good old "Fatshark" goggles. -
RC Plane Autonomous Drone with Instumentation Video Downlink
09/02/2021 at 07:16 • 0 commentsThis RC foam plane was converted into a autonomous flying platform
with GPS, autopilot, IMU stabilisation, return to home, and a LOT of videolink
overlayed instrumentation information. See the downlink video here: -
240-LED, Ultra-Bright 3-Channel Audio VU Meter
09/02/2021 at 07:15 • 0 commentsThis module takes an audio signal, splits it into low, mid & high
frequencies and then pulses 3 different sets of 10-segment bar graphs
(each segment is 8 blue LEDs in series). With the other components
included I had to solder 600+ total pins! -
Linear Voltage Dropper Module (THE HEAT EJECTOR)
09/02/2021 at 07:15 • 0 commentsI needed to drop the voltage of various supplies in a simple and fun way.
This device performs a adjustable fixed voltage drop of 0-25V at
ludicrous currents. The massive heat sink and 10W fan allowed for 100W+
of dissipation (it's a hairdryer). -
Zero-Bias Current Class-AB Audio Amplifier
09/02/2021 at 07:14 • 0 commentsA very old "relaxing" audio amplifier project with an input powered from
+/-12VDC (SLA batteries). The audio signal is sent through an OPA2134
preamp and then to a BD135/BD136 power stage. With zero bias current,
it relies entirely on feedback! -
[WORK JOB] - Adding External PCIe Boards to an Embedded Computer (Stock Image)
09/02/2021 at 07:14 • 0 commentsUsing Solidworks and a 3D printer I created a "slab" to sit below the
computer that housed: Two PCIe boards, mini-to-PCIe converters/"risers",
a fan/filter, a ventillator port, power entry (fan) & a modified computer
hatch cover. Very tedious... -
[WORK JOB] - USB-to-BNC 5V Trigger Box
09/02/2021 at 07:14 • 0 commentsWith a USB/BNC I/O, this box switches the BNC output from 0V to 5V
when the emergency stop button is pressed. Doing so also switches the
LED indicator from red to green. Printed in 4 colours using the Prusa
MK3S MMU2S, it simply looks beautiful! -
[WORK JOB] - High Frequency Wireless Energy PCB (Stock Image)
09/02/2021 at 07:13 • 0 commentsThis PCB is basically a custom wireless phone charger designed to
power/communicate with another module. The micro utilised is the new
Teensy 4.0 and the switching MOSFETs are PN: "RJK0855DPB". 80V,
30A, 11mohms & 10/20Vgs 35nC gate? Yes please! -
[WORK JOB] - LED Pulser PCB
09/02/2021 at 07:13 • 0 commentsThis PCB turns on a high speed LED as fast as practically possible. Using
a fast MOSFET to charge the inductor current down one path, it can
quickly divert that current through the LED path when needed. LR decay
allows for a peak/cont. current. -
[WORK JOB] - Hardware USB Interface Module Enclosure
09/02/2021 at 07:12 • 0 commentsThis module contains a PCB that interfaces a piece of legacy analogue
hardware with the USB standard. The enclosure features 2 OLED LCDs, 3
LED buttons, a power switch, fuse holder, 3-state LED, 2 fans, 2 I/O row
segments, 3 BNCs & a USB port. -
[WORK JOB] - Deployable & Networked Rack Computer Nodes (Stock Image)
09/02/2021 at 07:12 • 0 commentsThese nodes contain a computer supported by the necessary hardware
to allowed ruggedised, reliable and rapid deployment for node to node
networking with remote operation in mind. 32 system level I/O cables
have been patched to the front panel! -
[WORK JOB] - Network Wide Trigger System (Stock Image)
09/02/2021 at 07:11 • 0 commentsNeed rugged I/O accross a network? These boxes will take an input logic
state at any one node and replicate the state at all the other nodes via an
ethernet port. Local signal in > Ethernet > Remote signals out. (Main PCB:
Denkovi DAEnetIP3-ET) -
Remotely Controlled Alarm: Buzzer Box 3000!
09/02/2021 at 07:11 • 0 commentsUsing Fusion 360 for the two-part 3d-printed enclosure, this (electrically)
simple project contains 8*AA batteries (12V), a DPDT on/off/on switch, a
wireless relay module/remote, a LOUD two-tone piezo buzzer and a
volume control potentiometer. -
[WORK JOB] - Test Jig No.4
09/02/2021 at 07:09 • 0 commentsWe developed a unit to test motherboard PCB assemblies semiautomatically
through the use of test pins, relay boards, loads banks,
LabJack DAQs & programmable power supplies. A PC running LabVIEW
was used for interfacing & control. -
Simplified Galileo's Pendulum Escapement
09/02/2021 at 07:08 • 0 commentsBased on Galileo's Pendulum Escapement, I designed a simplified
mechanism that is suited to 3D printing. Several compromises were
made in the name of simplicity, but overall I am very happy with the
result! See here: -
[WORK JOB] - Test Jig No.3
09/02/2021 at 07:08 • 0 commentsWe developed two units to test the functionality of complete product
assemblies. The tester checks wiring logic, device output voltages and
harness impedances. All processes are controlled and logged via a
μcontroller & PC terminal. -
[WORK JOB] - Test Jig No.2
09/02/2021 at 07:07 • 0 commentsWe developed a unit to test 5x5 arrays of panelised PCB assemblies.
This tester contains test pins, relays, light sensors and light piping - All of
which is duplicated 25 times and addressed via a μcontroller through
demultiplexers. -
[WORK JOB] - Test Jig No.1
09/02/2021 at 07:06 • 0 commentsGiven existing test hardware and a complete assembly, I was tasked with
creating a μcontroller control module for automation.
Features/interactions include an RS-485 MODBUS line, a USB keyboard,
an LCD screen and an SD card reader. -
Fun Induction Motor Demo
09/02/2021 at 07:05 • 0 commentsA copper disc with three closely positioned 3-phase solenoids that
induce a rotational torque in much the same way as the modern
induction machine does. It is driven by a 12V, 3-phase inverter made of
spare parts: -
150g Combat Robot for Adelaide Robot Combat (ARC)
09/02/2021 at 07:05 • 0 commentsA weapon-less pusher type, this 150g 3D printed robot is defined by its
interchangeable armour, absurdly fast/powerful 15W motors, wide tyres
and gyro stabilisation. A demo of the robot (gyro ON) can be seen at: -
PV Peltier Water Collector
09/02/2021 at 07:04 • 0 commentsUsing 45 Watts of PV power (~18V MPP), two 30W Peltiers (0-9V), an
MPPT buck converter (IV-matching) and a temperature switch (anti-frost),
water is slowly collected at the cold-side heat sink where it falls through
a funnel and into a bottle. -
Breadboarded 80-LED Analogue Oscilloscope
09/02/2021 at 07:03 • 0 commentsA very old project. By using a single VU meter IC (LM3915?) and a
another IC that sequentially connects the columns of LEDs to ground (i.e.
the time scale), the VU meter effectively "sweeps" across the waveform in
a quick succession. -
Pulsed 800A Thyristor Solid State Switch
09/02/2021 at 07:03 • 0 commentsTo control the discharge of my 50V/0.3F capacitor bank in a modular
fashion I took an 800A peak thyristor, a piezo buzzer, a 9V battery and a
momentary switch and then stuffed them all into an off the shelf project
box with power I/O terminals. -
Class-D Custom Bluetooth Speaker Unit (36W Max)
09/02/2021 at 07:02 • 0 commentsA 60W 12V plug pack power supply is boosted to 24V, which is then fed
to a 50W class-D amplifier with bluetooth audio receiving capability. The
output is then split at 3.8kHz with a 2nd order high & low pass filter for
the 8Ω tweeter & woofer. -
Peltier Freezer Ice Crystal Time Lapse
09/02/2021 at 07:00 • 0 commentsTwo cascade Peltier units (top: adjusted to ~36W, bottom: ~72W) This
draws about 9-10 amps total at 12V. Heat pump transfer is 15W optimally
and the minimum cold side temp reaches -30°C. See: -
128W Full-Bridge Class-D Audio Amplifier
09/02/2021 at 07:00 • 0 comments32V & 4A input, 600kHz switching frequency and a soft start relay. These
amplifiers are very hard to design but are very rewarding when they are
done right. I would highly recommend them for anyone that wants to
learn about power electronics. -
Talking Animatronic Gundam Robot
09/02/2021 at 06:59 • 0 commentsContains 6 servos, a text-to-speech unit, glowing eyes, audio reactive
LEDs throughout, a spinning gun, power supply, audio amplifier, music,
transformer, a brain and manual controls! See it here:
www.youtube.com/watch?v=E8185o7we04 -
180W Variable Linear Power Supply
09/02/2021 at 06:59 • 0 commentsA 1-30V, 6A linear power supply housing a TO-3 regulator, circuit and a
serious heat sink. Features include: A soft start relay, a temperature-based
two speed fan, under/over voltage alarms and disconnects,
various displays & indicators + more! -
MATLAB Code for 3D Printing Math Functions
09/02/2021 at 06:57 • 0 commentsI thought it would be a fun idea to visualise some math functions as 3D
prints. The MATLAB script that I created took an equation, converted it to
a surface plot, added a solid base underneath and generated an STL file
for 3D printing. -
PhD 4/4: Inverter H-Bridge Decentralised Cascaded System
09/02/2021 at 06:56 • 0 commentsI put together 4 control boards and 4 H-Bridge power stages to make a
decentralised multilevel cascaded grid-tied inverter. The input is DC
power which is converted and sent back to the grid. Effectively, this
system educates and heats the room. -
PhD 3/4: Bi-Directional Analogue/Digital 3.3V to 5V Converter
09/02/2021 at 06:55 • 0 commentsNow you think I would have realised that a serious H-bridge should be
operable from 3.3V. Well I stuffed that up and as a result I needed a way
to allow my 3.3V microcontrollers (Arduino Due) to interact with my 5V Hbridges
and their sensors. -
PhD 2/4: Inverter H-Bridge Power Stage V2.0
09/02/2021 at 06:55 • 0 commentsThe final version of the H-bridge for the cascaded inverter of my PhD.
This final version was much more robust, had a LOT of protection and
other features that made controlling it so much simpler. To date, non of
these boards have failed in use. -
PhD 1/4: Inverter H-Bridge Power Stage V1.0
09/02/2021 at 06:54 • 0 commentsDuring the earlier stages of my PhD I realised I would need H-bridges for
my cascaded inverter at a later point. I went about designing and
constructing a very early version of the H-bridge to test. This was the first
time I had used Altium. -
Align Trex 550 Helicopter Assembly
09/02/2021 at 06:53 • 0 commentsThe Align Trex 550 is a 1400W model helicopter with a body length of 1
metre and a battery life of 10 minutes. Assembling this allowed for a deep
understanding of the mechanics of helicopter flight and maintenance.
Very educational! -
Prusa i3 3D Printer Assembly
09/02/2021 at 06:51 • 0 commentsTo enter the world of 3D printing I purchased a Prusa i3 1.75mm from the
official website and put it together. This was an exercise in mechanical
assembly and greatly deepened my understanding of how 3D printers
work. -
Class AB Amplifier (Stereo 15W)
09/02/2021 at 06:51 • 0 commentsMy first "serious" amplifier project! A dual 15W class AB amplifier with a
bias current of about 1A per channel (that's a total standing heat
dissipation heat of near 60W)! Summary: Dual Transformer-->Rectifiers --
>Caps-->+/-15V-->Amp ALSO FAN! -
FPV RC Car
09/02/2021 at 06:50 • 0 commentsA 200W remote control car with video/audio transmission. Features
include a front/rear camera (with pan/tilt), front(10W)/rear(1W) headlights,
rear microphone, 900MHz video with OSD, 2.4GHz control, and a fluffy
doll for attracting children. -
Room Automation Board
09/02/2021 at 06:47 • 0 commentsUsing a micro-controller and the insides of a remote from a network of
wireless mains relays, I automated the devices in my room. There is a
motion sensor, a wireless "bedtime" switch and a set of pre-programmed
configurations. -
50V Capacitor Bank
09/02/2021 at 06:45 • 0 commentsA 50V capacitor bank made up of 10mF caps (31 of them). The total
maximum energy is 387.5 joules. There is a controllable bleed resistor
and voltage/current multimeters powered by a single 9V battery. The
ultimate DC-link capacitor! -
Tick tock goes the even larger 3d printed clock
02/14/2021 at 07:27 • 0 commentsThe cad files (not mine): https://www.thingiverse.com/thing:3364860
See the "make": https://www.thingiverse.com/make:903447 -
Playing some MIDI tunes on piezo buzzers!
07/08/2020 at 22:42 • 0 commentsOne of those things that is simple to implement with libraries, but very delightful to experience!
Snippet No.6
07/23/2018 at 11:08 • 0 comments35 lots of 3-6hr prints and a kg of filament later... I have my 80cm Shanghai Oriental Pearl!
See: https://www.thingiverse.com/thing:1622786/ for the designer of the print and https://www.thingiverse.com/make:517373 for the "make".
Snippet No.5:
07/14/2018 at 12:31 • 0 commentsFinished printing a kinetic water sculpture from Thingiverse:
See: https://www.thingiverse.com/thing:2542655 for the file and https://www.thingiverse.com/make:518086 for the "make".
Snippet No.4:
04/28/2018 at 00:31 • 0 commentsFinished a 200% scale flying Tourbillon from the same author on Thingiverse:
See: https://www.thingiverse.com/thing:2751917 for the file and https://www.thingiverse.com/make:518083 for the "make".
Snippet No.3:
04/19/2018 at 03:13 • 0 commentsHaving some fun with a portion of a flying tourbillon from Thingiverse:
(https://www.thingiverse.com/thing:2751917) -
Snippet No.2:
03/25/2018 at 06:38 • 0 commentsI'm starting to gather a little collection on my desk this week!
Snippet No.1:
03/21/2018 at 09:51 • 0 commentsFun UGEARS kit that I received as a gift (pneumatic engine):
