Intersil IM6100 Intercept junior like
04/18/2021 at 17:05 • 2 comments![]()
When I was student in 1979 my solar project need to drive a equatorial parabola.
I decided to use IM6100 and test application program with an Intercept Junior and TTY.
In 2018, During dismantling cubicle in a room, I found old boards with IM6100.
My idea was to retro build a Intercept Jr like board with CPU and other chips.
After drawing schematic on Eagle, I weld about 900 wires on double side universal board.
To load program code in EEPROM memory I use Microduino board ATMEGA 1244. `
For access, DMA pin is activate to allowed Microduino loading 12 bits CPU codes.
Recently I found Smal8.c source file of PAL III Pdp8 assembler. I adapt application for the board compile and use with Sublimetext3 build menu. perfect !
So I decide to test RS232 connection and I2C line to drive LCD 20x4.
