low consumption motor
11/14/2018 at 20:07 • 0 commentsLow consumption motor
Objective : to build an electric motor operated under low power (voltage and current) , powered by a single small solar panel which can operate in the artificial light and which can be transformed in a small electric dc generator.
VIDEO 1. : TEST 1 "Low consumption motor"
Neodymium sphere 19 mm diameter - the key component
Material NdFeB Shape, Sphere Diameter 19 mm Tolerance +/- 0,1 mm, Coating Chrome-plated (Ni-Cu-Ni-Cr), Manufacturing method sintered Magnetisation N38 Strength approx. 4,9 kg (approx. 48,1 N), Max. working temperature 80°C, Weight 27,2943 g, Curie temperature 310 °C, Residual magnetism Br 12200-12600 G, 1.22-1.26 T, Coercive field strength bHc 10.8-11.5 kOe, 860-915 kA/m, Coercive field strength iHc ≥12 kOe, ≥955 kA/m, Energy product (BxH)max 36-38 MGOe, 287-303 kJ/m³ 19 mm , Pollutant-free according to RoHS Directive 2011/65/EU._ _
Important : the metal cases with screws should be positioned : one to the N magnetic pole of the neodymium sphere 19 mm diameter and the second one on the Smagnetic pole of the sphere. ( In the presented Video 1. , at the first test, the metal cases weren't properly placed on the sphere and the motor doesn't reached the full speed )
In the upper side of the sphere there is no friction between the screw and the iron
Input DC power - mini solar panel -VIMUN SC-3012-2A, 29.44mm×11.6mm×1.1mm, 4 cells
There are a total of four electrical components. A small solar panel ( VIMUN SC-3012-2A, 29.44mm×11.6mm×1.1mm, 4 cells. The following specifications were listed, 2.0 Vos, 9.0 UAsc, 1.5 Vop, at 200Lux), a 470 uF 10 V electrolytic capacitor, a coil iron less with thin copper wire and a small circuit board with a black blob on it.
Under this blob is the integrated circuit chip. It provides the correctly timed pulses to the coil and magnet combination. The integrated circuit is more or less just a low frequency oscillator which runs at approximately 1 Hz most likely driving an open drain NMOS switch ( output on pin 3 ) which periodically connects the coil to the - terminal. The circuit pulses the 18 mH coil causing the neodymium sphere magnet spinning.
electrical components used (excepting the coil iron less ) - from a solar powered flapping toy.
fidget spinner generator reaching 100 V
09/22/2017 at 09:03 • 0 commentsfidget spinner electric generator reaching 100 V using neodymium sphere 30 mm, a coil iron - less, a bearing (holder for the 30 mm neodymium sphere) 3 sphere fidget spinner extra weight and a led bulb 9W 230 V
mini generator 230 V lighting bulbs 3 w - 75 W
08/29/2017 at 09:32 • 0 commentsmini generator 230 V lighting bulbs 3 w - 75 W , using a single neodymium sphere 19 mm - 30 mm , 1 or 2 coils iron - less 40 ohms each , pot metal case, 3,7 V Dc motor, 1 - 2 batteries 3,7 V.
2. small generator lighting 11 W Hg bulb 230 V
3. electric generator lighting 28 w bulb 230 V
the smallest generator 230 V
08/29/2017 at 09:26 • 0 commentsthe smallest generator ac 230 V lighting 3 W Mr 16 led using a single neodymium sphere 10 mm diameter and a small Dc motor from a CD ROM, powered with a 1.2 V battery.
generator 230 V lighting bulbs 3 W - 9 W
08/29/2017 at 09:22 • 0 commentssmall generator 230 V lighting bulbs 3 W - 9 W using a single sphere 13 mm diameter + coil iron -less from a syncronous motor + battery + 3 V dc motor + pot metal case.
1. small generator using 13 mm neodymium sphere ( rotor ) lighting 3 led bulbs 230 V 7 W
08/29/2017 at 09:15 • 0 commentsfidget spinner electric generator
fidget spinner generator using 3 neodymium magnet disc + coil iron - less + led + fidget spinner
fidget spinner generator 2
fidget spinner generator using a single neodymium magnet disc ( not moving ) under the fidget spinner + coil iron - less + led + fidget spinner
