Bithacks Poster
11/21/2015 at 08:44 • 0 comments
TIME_WAIT: Random Notes
08/22/2015 at 08:12 • 0 comments[Just a draft - please ignore for now]
We have all seen it. TIME_WAIT sockets piling up and all hell breaks loose. This is an attempt to document all there is to know about this, so that we can learn how to address the issue better and move on with our lives.
TIME_WAIT has been around for a while. We see it for the first time in the good-old RFC 793 (Sept 1981):
TIME-WAIT - represents waiting for enough time to pass to be sure the remote TCP received the acknowledgment of its connection termination request.
RFC 793 specifies that a connection can stay in TIME-WAIT for a maximum of four minutes. Most modern Linux systems seem to be setting the Maximum segment lifetime value at 60 seconds.Open Question: Does it make sense to have an uniform tcp_fin_timeout value for all sockets? Shouldn't it be routing sensitive? Localhost connection values should be order of magnitude lower.
Fundamental problem here is that TIME_WAIT is entered after the invoking side close()s the connection on their side but socket is still left hanging around to wait for other side to do the close(). Given that there's no handshake in this process, an oblivious process is required, hence the sleep.
Can parallels be drawn between TIME_WAIT sockets and "zombie" forks? Not quite - as TIME_WAITs have a time limit
Classical problem is combination of fixed input socket rate, 2/4min TIME_WAIT and a limit on the number of file descriptors. Given the request volume of X queries/sec, the expected number of sockets become:
So for a host with 10 req/sec and standard MSL of 60sec, expected number of TIME_WAIT sockets on the host will be 1200. With a standard ulimit of 1024 open files, that means we're already deep in trouble.
Useful Links
- http://vincent.bernat.im/en/blog/2014-tcp-time-wait-state-linux.html - do not enable net.ipv4.tcp_tw_recycle
- http://www4.cs.fau.de/Projects/JX/Projects/TCP/tcpstate.html - a bit more modern TCP state transition diagram
Chapters on Computation: Zero
08/10/2015 at 13:49 • 0 commentsA lovely doc popped up on Hacker News yesterday:
"Semaphores in Plan 9" by Sape Mullender and Russ Cox https://swtch.com/semaphore.pdf
Not much but a great textbook-level reminder on different synchronization mechanisms and their performance. The foundational one that people tend to forget about is P9's Rendezvous. So where's the Rama?
FAIR deep-learning modules for Torch
01/18/2015 at 20:22 • 0 commentsFb has open sourced some deep learning modules for Torch. Let's see what's that all about.
https://github.com/facebook/fbcunn
References
http://torch.ch - Lua scientific computing framework
http://arxiv.org/abs/1412.7580
https://github.com/facebook/fbcunn - main FAIR repo
http://nlp.stanford.edu/projects/DeepLearningInNaturalLanguageProcessing.shtml - Stanford NLP Deep Learning page
http://nlp.stanford.edu/courses/NAACL2013/NAACL2013-Socher-Manning-DeepLearning.pdf - excellent presentation on Deep Learning for NLP
Clojure OpenNLP / Code Review
01/15/2015 at 01:08 • 0 comments[Just a test]
People loves OpenNLP (https://opennlp.apache.org) and it feels like Clojure would be a good environment for it. This should be the bridge...
Example code
(ns examples.web-tag (:use [opennlp.nlp]) (:use [clojure.pprint :only [pprint]])) (def get-sentences (make-sentence-detector "models/en-sent.bin")) (def tokenize (make-tokenizer "models/en-token.bin")) (def pos-tag (make-pos-tagger "models/en-pos-maxent.bin")) (defn strip-html-tags "Messily strip html tags from a web page" [string] (-> string (.replaceAll "<script .*?>.*?</script>" " ") (.replaceAll "<style .*?>.*?</style>" " ") (.replaceAll "<.*?>" " ") (.replaceAll "[ ]+" " "))) (defn fetch-page [url] (let [html (.replaceAll (slurp url) "[\t\n\r]" " ")] (re-find #"<body.*?</body>" html))) (defn fetch-plain-page [url] (strip-html-tags (fetch-page url))) (defn- tag-sentences [sent-seq] (map #(pos-tag (tokenize %)) sent-seq)) (defn tag-page [url] (let [page (fetch-plain-page url) sentences (get-sentences page) sent-seq (partition-all 10 sentences)] (pmap tag-sentences sent-seq))) (tag-page "http://writequit.org") (ns examples.web-tag (:use [opennlp.nlp]) (:use [clojure.pprint :only [pprint]])) (def get-sentences (make-sentence-detector "models/en-sent.bin")) (def tokenize (make-tokenizer "models/en-token.bin")) (def pos-tag (make-pos-tagger "models/en-pos-maxent.bin")) (defn strip-html-tags "Messily strip html tags from a web page" [string] (-> string (.replaceAll ".*?" " ") (.replaceAll ".*?" " ") (.replaceAll "<.*?>" " ") (.replaceAll "[ ]+" " "))) (defn fetch-page [url] (let [html (.replaceAll (slurp url) "[\t\n\r]" " ")] (re-find #"" html))) (defn fetch-plain-page [url] (strip-html-tags (fetch-page url))) (defn- tag-sentences [sent-seq] (map #(pos-tag (tokenize %)) sent-seq)) (defn tag-page [url] (let [page (fetch-plain-page url) sentences (get-sentences page) sent-seq (partition-all 10 sentences)] (pmap tag-sentences sent-seq))) (tag-page "http://writequit.org") (ns examples.web-tag (:use [opennlp.nlp]) (:use [clojure.pprint :only [pprint]])) (def get-sentences (make-sentence-detector "models/en-sent.bin")) (def tokenize (make-tokenizer "models/en-token.bin")) (def pos-tag (make-pos-tagger "models/en-pos-maxent.bin")) (defn strip-html-tags "Messily strip html tags from a web page" [string] (-> string (.replaceAll ".*?" " ") (.replaceAll ".*?" " ") (.replaceAll "<.*?>" " ") (.replaceAll "[ ]+" " "))) (defn fetch-page [url] (let [html (.replaceAll (slurp url) "[\t\n\r]" " ")] (re-find #"" html))) (defn fetch-plain-page [url] (strip-html-tags (fetch-page url))) (defn- tag-sentences [sent-seq] (map #(pos-tag (tokenize %)) sent-seq)) (defn tag-page [url] (let [page (fetch-plain-page url) sentences (get-sentences page) sent-seq (partition-all 10 sentences)] (pmap tag-sentences sent-seq))) (tag-page "http://writequit.org")
