Touch WiFI Smart Switch app installation demo smart home smart life PINC Technology
06/10/2020 at 04:13 • 0 commentsSmart WiFI Switches based on #tuya #smartlifeapp to make you home #smarthome. The #smartswitches starts from 499 INR & compatible with #anchorroma standard. #wifitouchswitch supports #alexa and #googlehome
WiFI Touch Switch connect the google home PINC Technology
04/29/2020 at 05:49 • 0 commentsTouch WiFi Switch converts your current home to a smart home with wifi interface. Modular touch wifi switch comes with anchor/Roma standard. The smart switch will fix in all the anchor Roma boards and plates. The touch switch is made up of a high-quality capacitive touch sensor. It will supports ewelink/Sonoff app for smart home automation. The wifi modular touch supports the Amazon Alexa, Google Home, IFTTT.
In this video we are going to show how to connect our WiFi Smart Switch with the google home. To know the procedure go to the main menu setting in ewelink.
Click on the google home.
It will show you the full procedure for the connect the google home with the ewelink app.
Now to controll this switch with google home just go to google home app.
Tap on plus button
Go to setup device
Go to have a somethong allready setup
Go to ewelink smart home
it will open one browser page, just give your credential here
Hit on login
And now you can see that one device is added to google home page.
Move that device to you rooms, here i am am move this to my bedroom. And now you can turn on and off this.
WiFi Touch Switch How to download, install and use the mobile app PINC Technology
04/29/2020 at 05:46 • 0 commentsTouch Switch converts your current home to a smart home with wifi interface. Modular touch wifi switch comes with anchor/Roma standard. The smart switch will fix in all the anchor Roma boards and plates. The touch switch is made up of a high-quality capacitive touch sensor. It will supports ewelink/Sonoff app for smart home automation. The wifi modular touch supports the Amazon Alexa, Google Home, IFTTT.
In this video. we are going to show you how to install the eWlink app for your android or iOS play store and configure our modular wifi touch smart switch
Download and install eWlink from google or iOS AppStore.
Register yourself by giving email id and mobile number if you use the first time this app. Make sure that you are in provision mode.
How to check the device is provision mode?
The BLUE LED will blink 3 times per second then the device is in provision mode.
This switch is the combination of the wi-fi and touch. Now you can order this switch from Amazon, Flipkart, Snapdeal, Club factory, etc.
This switch supports Amazon Alexa, IFTTT, google home. This switch operates from 85 volt AC to 265 volt AC with 50 or 60 Hz frequency.
It supports 10 amp of current. The wi-fi is IEEE compliance with b, g,n mode with 2.4 Ghertz frequency. The size of the switch is very small 50X45X24 mm. The wiring of this switch is very easy.
There are only 4 wires. 2 wires are input and 2 wires for the output.
The switch is compatible with the anchor Roma standard which is specially designed for the Indian standard. You can turn this on and off by mobile phone as well as touch.
Smart WiFi Touch Switch ewelink app PINC Technology
04/29/2020 at 05:42 • 0 commentsPinc technology manufactured the WiFi touch switch for smart home automation. In this video. we are going to show you how to install the eWelink app for your android or iOS play store and configure our modular wifi touch smart switch.
Download and install eWelink from google or iOS AppStore.
You can mail us on business@pinctechnology.com
For bulk inquiry please contact us on WhatsApp business or call us on 6351519021 or 9925020032.
Read more
