Hacking a Bluetooth / Wifi enabled Trailcam
07/18/2023 at 23:23 • 0 commentsI recently came across a deal on ebay for a low cost Bluetooth / Wifi enabled trail cam and decided, it might be worth a look.
After receiving the item, I was less than pleased with the functionality and the need to use the very poorly designed app. So I did what any hacker would do with no free time and too many projects on the back burner already... Start another project to see what I could do with a little reverse engineering and code!
https://hackaday.io/project/191999-hacking-a-bluetooth-wifi-enabled-trailcam
