Robot building lessons learned
07/27/2019 at 01:06 • 0 comments- Mount motors with the heads facing the wheel to keep the wheels from rubbing against the protruding bottoms.
- Verify voltages (ex. the HC-SR04 plague).
- Superglue is neat but superglue mounts, not sensors - unless you're sure about voltages. Replacing superglued parts is hard.
