LLM Architecural Defect Ananlysis Videos
10/14/2026 at 01:09 • 0 commentsThe purpose of this is to point our research in the right direction. LLMs are pretty cool but they have a lot of weaknesses. I'm currently working on a series of videos on the subject. I'll add videos here as I create them.
Standard PCB Measurements and Dimensions
05/17/2024 at 14:29 • 0 commentsThis page is for me to drop measurements and dimensions on various PCB layouts, especially for ones I've spent way too long searching to find. Hopefully we won't have to dig as deep to find them after this.
First one: Pico-ITX. For some reason getting dimensions for this is very difficult. Here's measurements for a reference design: I found it in this PDF: https://linuxdevices.org/ldfiles/misc/Pico-ITX_Form_Factor.pdf
Nano-ITX:It's from https://macroems.ru/modul-nano-itx/
Mini-ITX, just so we're complete:From https://cdn.instructables.com/ORIG/FJD/TETT/GU59XBKK/FJDTETTGU59XBKK.pdf
I'll add more to this later if there's some other board layout I can't find info on. -
Test Page
07/28/2019 at 20:06 • 28 commentsDo whatever here, making this page so I can do experiments on HaD comments etc
Edit:
SUCCESS. WE HAVE MADE A COMMENT WITH NON-PRINTABLE CHARACTERS ONLY! -
Ethereum Dapp Page
06/08/2019 at 18:59 • 0 comments -
Inventory of all my chips
04/06/2017 at 15:28 • 3 commentsChip Quantity Description 74175 4 4 bit register with universal clock 74174 1 6 bit register with universal clock 74173 11+ quad D flip-flop, tri state, asynchronous clear 7445 1 BCD to decimal decoder 74161 13 pre/resettable 4-bit counter 74hc147 2 10-to-4 line encoder 74151 2 8 line multiplexer 7404 14 hex inverter 7405 1 hex inverter, open collector outputs Intel 2114A 3 1024x4 SRAM 74181 16 4 bit ALU 7432 15 quad OR gate 7414 4 hex Schmitt trigger inverter 7410 2 triple 3-input NAND gate 7420 8 dual 4-input NAND gate 7400 1 quad NAND gate 7408 4 quad AND gate 7474 1 2 D flip-flops 7427 1 triple 3-input NOR 7440 1 don't get what this is - dual 4-inp. NAND? 74126 1 quad tri-state bus buffer 744075 1 triple 3-inp. OR gate 7486 3 quad 2-inp. XOR gate 74132 1 quad NAND Schmitt trigger 74163 1 presettable 4-bit binary counter (sync. clear) 74138 2 3-to-8 line decoder 74629 1 dual voltage controlled oscillator 74259 1 8 bit adressable latch 74367 1 hex buffer tri-state 74595 4+ serial input shift register 8 bit 74166 1 parallel load 8-bit shift reg. 74191 1 presetable up/down binary counter 744040 1 12-stage binary ripple counter P2114A 3 512 bytes RAM, as 1Kx4 bits idt 71256 3 32k 9ns SRAM mc14011 4 quad 2-inp NAND gate (CMOS, 4011 alias) mc14040 4 12-stage binary ripple counter (CMOS, 4040 alias) mc14490 1 hex contact bounce eliminator (CMOS, 4490 alias) mc14512 2 8-input tristate multiplexer (CMOS, 4512 alias) 4001 1 Quad 2-input nor gate 4013 2 dual d flipflop 4020 2 14-stage binary ripple counter 4027 1 Dual J-K master-slave flip-flop 4056 1 BCD to 7-segment 4071 1 quad 2-input or gate 4073 2 Triple 3-input and gate 4081 too many quad 2-input and gate I think my MC14000s may be related to an MC14500 somewhere, but I can't look for it right now. That would be very interresting!
