Augmented Reality Tutorial No. 44: Kudan SLAM Similar Technique Used in Pokemon Go
MORE ON AUGMENTED REALITY: WWW.OURTECHART.COM
This is Augmented Reality Kudan plugin tutorial, in which we experiment with image tracking and SLAM technique, in which no image target is used. In general, SLAM is the technique that analyzes the environment itself and using some usefull features from the environment it can estimate user device orietation and position. In respect to that, virtual content is represented.
Download # Newest version of Unity3D 64 bit (this is important) is available from here
Download # Download and Import Kudan plugin 1.2.2 for Unity (KudanARUnity) (*.unitypackage file)
Unity3D extension is also available to download from here (there might be even a newer version)
Download # Print/Use Stones Image Tracker (*.jpg file)
Download # You Can Create Tracker using this Windows Toolkit from Kudan (*.exe file)
Download # You Can Use Already Created Tracker Based on Windows Toolkit (*.KARMarker file)
Download # C# enabled.cs code (*.cs file)
Download # Download Whole Augmented Reality Kudan Tutorial Project Files (the result to test it) (*.rar file)
Download # You can also try the app on your Android device (*.apk file)
Edgaras Art
