KCP53000B Processor Specs Drafted
A project log for Kestrel Computer Project
The Kestrel project is all about freedom of computing and the freedom of learning using a completely open hardware and software design.
samuel-a-falvo-iiSamuel A. Falvo II • 03/16/2019 at 03:14•1 Comment
Per the last project log, I will be working on a revision of the KCP53000 suitable for proving the Kestrel-3 design.  As with all things on this scale of complexity, I'm starting out by drafting a crude set of specifications that'll help guide the development.  You can find the specs here: http://chiselapp.com/user/kc5tja/repository/kestrel-3/artifact/d0c100b35693b93b
Wladimir van der Laan wrote 04/09/2019 at 07:29 • point
Very cool work, I like the concise but clear description of the RISC-V ISA architecture and registers and what applies to which CPU type, it's so unlike commercial vendor docs nowadays.
