Per the last project log, I will be working on a revision of the KCP53000 suitable for proving the Kestrel-3 design. As with all things on this scale of complexity, I'm starting out by drafting a crude set of specifications that'll help guide the development. You can find the specs here: http://chiselapp.com/user/kc5tja/repository/kestrel-3/artifact/d0c100b35693b93b
Samuel A. Falvo II
Very cool work, I like the concise but clear description of the RISC-V ISA architecture and registers and what applies to which CPU type, it's so unlike commercial vendor docs nowadays.
