Datasheet Updated, Bugs Fixed
A project log for Kestrel Computer Project
The Kestrel project is all about freedom of computing and the freedom of learning using a completely open hardware and software design.
samuel-a-falvo-iiSamuel A. Falvo II • 11/26/2016 at 16:53•0 Comments
The datasheet for the KCP53000 has been updated. A new Example chapter illustrates a typical application of the CPU. You should be able to simulate the Verilog inside of Icarus Verilog at the least. At least, "it works for me."
In addition, the example code includes a prototype of the (unlabelled) KCP53001 Furcula bus arbiter, which is used to convert the CPU's native Harvard architecture interface to a Von Neumann/Princeton architecture interface. It further includes a crude prototype of what will eventually become the KCP53002 Wishbone bus bridge/adapter as well. Together, the KCP53000, KCP53001, and KCP53002 forms a processor complex which can replace the S16X4 in the Kestrel-2. With some address space changes (which involve changing the emulator too), I should be able to realize a prototype of the Kestrel-3 in relatively short order. I still need to work on the Wishbone arbiter and the external SRAM interface.
I also discovered a surprise when trying to use the SLT and SLTU instructions. They always returned 0, even when the expected condition held true! This was due to some missing connectivity both within the ALU circuit and between the ALU and the execution state machine. This has been fixed.
If anyone is attending the 5th RISC-V Workshop, I will be giving a poster session there, and will have a hard-copy print-out of the datasheet for public review. Once again, I'll have my laptop computer available running the Kestrel-3 emulator, with eForth 1.0 running in (emulated) firmware.
I was hoping to have a simple game written that people can interact with, but alas, time is running much too short for me. Maybe next year, and maybe on a real FPGA system!
