I recently completed the first implementation of the circuit that will enable me to deploy my CPU on a real FPGA: the 64-bit to 16-bit Furcula bus bridge. This bridge supports not only 8- and 16-bit transfers, but also includes a state machine to support 32- and 64-bit transfers as well. NOTE:Datasheets for this component does not yet exist, but I'm hoping the circuit interface is easy enough to figure out by looking at the Verilog module header. I will provide documentation at a later date.
This bridge allows the host CPU, which relies on a 64-bit architecture, to interoperate with a 16-bit path to memory, which is what most FPGA developer boards offer.
