RX Pipeline
I managed to implement a Remex receive pipeline which I'm happy with. It's capable of supporting arbitrary bit rates up to RxClk(Hz)/4 bits per second throughputs safely, although you can probably push it to RxClk/3 bits per second. It deposits all data characters (all N-chars and EOP and EEP characters) into an 8-deep 9-bit FIFO. The FIFO has a (very!) degenerate Wishbone B4 interface on it, so it should be quite easy to couple to a Wishbone B3 or B4 interface later on.
Because of the high peak throughputs on the Remex interconnect combined with a very shallow FIFO, traffic over the interconnect will "stutter" quite frequently, consisting of bursts of activity separated by intervals of idle activity. I expect real-world throughput to not be that fast until I deepen the FIFO and/or attach a DMA interface to the pipeline. Both are planned, but I need to make sure I have enough room for them first!
TX Pipeline
My next set of tasks includes getting the transmit pipeline working. TxClk will be derived from RxClk using a programmable down-counter. This lets the host control transmit data rate with about as much control as you'd typically find in a UART. I'm still trying to figure out overall architecture of the TX pipeline.
Miscellaneous
I should note that the RX pipeline, having only an 8-deep queue, consumes around 300 logic cells in the iCE40 parts. I'm guessing that the TX pipeline will take up about as much space, but I won't know until its done. I have no estimate for the Wishbone bus interface yet. This already means I cannot implement a lot of independent channels, so I'll probably restrict myself to just 3 or 4. It could be as small as 2.
(EDIT: Through a conversation I had on IRC shortly after posting this article, I was referred to this paper which suggests a reasonable implementation size for a complete SpaceWire interface comes to around 460 LUTs. I think it's reasonable, then, to speculate my implementation will weigh in around 600 LUTs, accounting for my relative lack of experience with FPGA design engineering. Further, the same paper suggests a maximum RX throughput of RxClk*2/3, rather than RxClk/3. Exciting!)
Pragmatically, it's not be as bad as it sounds; yes, it cramps my style, but we must remember that IEEE-1355 is designed to be a packet switched protocol. This means all packets have a (possibly source-routed) destination address field as the first n bytes of a frame. Thus, we can still support a large number of expansions by making use of switches. I was hoping to avoid having to do things this way especially at first, but having a smaller number of channels than planned is not a deal-breaker for me. Even one channel is, while inconvenient, still viable.
