Taking a break from job-hunting and my resume editor project, I wondered if I could do better than the Spacewire/IEEE-1355 when making a serial transmitter. To find out, I created the Experimental Serial Transmitter repository to find out.
This code is not production-grade. It's pretty amateurish, actually. It's probably buggy in certain edge-cases as well.
This transmitter should support between 1 and 64 bit transfers. I know it works between 1 and 63 bits; 64 bits is as-yet unproven and probably buggy. But, that's OK for now; this is just a prototype. Think "hack-day" project.
To use as an EIA-232/422/423/485 transmitter (which shifts data LSB first), you load the TXREG register with a bit pattern like follows:
63 : 10 | 9 | 8 : 1 | 0 |
11111....1111 | 1 | Data | 0 |
Bit 0 is the start bit, and must be 0 (since TXD idles high). Bits 8:1 comprise the 8-bit word you wish to send. Finally bit 9 is the stop bit, and must be set to 1. Bits 63:10 don't need to be set to anything per se, but it's good practice to set them to 1 just in case.
If you want to add parity, then you'll just stuff the parity bit in bit position 9, and the stop bit in bit 10. Simple.
The BITS parameter tells the engine how many bits to shift out (for 8N1 transmissions, you'll set this to 10. For 8E1 or 8O1, 11. Add one more again for each additional stop bit).
TXBAUD tells it how fast (how many system clocks per bit cell). The TXC output is automatically generated, and the circuit tries hard to maintain 50% duty cycle (regrettably, it cannot do this with odd baud rates, but it comes as close as it can).
As data is shifted out, the value of the RXD input is shifted in at bit 63. For EIA-232 uses, this is almost certainly not useful. It's best to treat this as garbage. However, if you loop TXD back to RXD, you could perhaps use this circuit as a crude 1-bit DAC as well.
To use this circuit as an SPI controller (which typically shifts data MSB first), you use the TXREGR register instead. This register is exactly like TXREG, except the bits are reversed:
0 : 7 | 8 : 63 |
Data | 00000.....000000 |
Note that the data you want to send now occupies the highest bits of the register, rather than the lowest. Be sure BITS is set to 8, or whichever is appropriate for the slave device. Note that you'll need a general purpose output to serve as slave-select. XST does not provide this signal on its own.
XST only supports SPI CPHA=1, CPOL=0 (mode 1). I'll play around with the circuit to see if I can also support the other three modes. CPHA=1/CPOL=1 (mode 3) should be trivially easy to support. CPHA=0, however, will require a bit of thought. The Verilog implementation, I think, is a bit too simplistic to support it without larger adjustments to the code.
Tip: If you want to cheaply bit-swap a word, write the value into TXREG, and read back via TXREGR (or vice versa). You'll need a way to disable the transmitter shift register engine, though.
Since RXD (which doubles as MISO) is always shifted into the register at bit 63, after an SPI word is sent, the received data will appear in the lower bits of the TXREGR register.
Credit where it's due: the primary inspiration is the Commodore-Amiga's PAULA chip's UART design.
