Since my last update, I've made many small and incremental improvements to the load/store unit and the register "write-back" side of the X-Register Set modules. To a reasonably good approximation, I think this completes 90% of my work on these stages. I think there are some small artifacts that need to be added still, but these will depend upon the cooperation of other units not yet written, so will have to wait.
With that said, I think it's time to start on the Integer Execute stage of the pipeline. This is the stage that basically encapsulates the ALU I've already written for the KCP53000.
LSU Features
The KCP53010's front-side bus will conform to Wishbone B.4 Pipeline Mode specifications. This new direction satisfies several problems I was having before with the KCP53000, allowing me to collapse several support modules into the core of the CPU effortlessly.
The B.3/B.4 Standard Mode/Furcula bus ties the master and slave side of the bus inextricably together, which required more sophisticated state machines when adapting to other buses. The 64-bit to 16-bit bridge (KCP53003) added a significant amount of overhead to the circuit, as did all the other bridges that were required to interface the KCP53000 to the Kestrel-2 hardware. It worked; but, it was very slow, and only just barely met timing requirements for a working computer.
The B.4 Pipelined operation greatly reduces the complexity involved with bridging different bus widths. Supporting 64-bit, 32-bit, 16-bit, and 8-bit transfers over a 16-bit external bus came surprisingly easy once I realized that the command and response (or master and slave, as referenced in the Verilog sources) sides of the bus can be cleanly divorced from each other. I'm banking on this simplification to reduce both layout pressure as well as bump the CPU's operating frequency to a more comfortable rate.
Disadvantages
Because I now natively support Wishbone, the CPU is now directly responsible for handling address misalignment and data path routing. Right now, the LSU doesn't take misalignment into consideration. This is a known bug, but will be addressed later. However, I'm thinking the hardware to detect and respond to this (and similar) condition(s) will still result in a net reduction in complexity.
