This project is for reasonably advanced electronic nuts...but if you stick with it anyone can make it.
If
you choose to build the Through Hole Technology (THT) version, then you
will be making a Printed Circuit Board (PCB) or at least a matrix
board, soldering electronic components onto it, and then programming a
PIC micro-controller, so you'll need:
- PCB making equipment. I use inkjet transparencies, an ordinary fluorescent desk lamp as a UV source, and Kinsten positive-acting presensitised board, and ferric chloride etchant.
- A good soldering iron with a fine tip. I soldered everything on both the THT and SMT boards with a Hakko T18-B 1 mm ball tip.
- A micro-controller programmer able to program a Microchip PIC18F2550 micro-controller, such as a Pickit2 or you can make your own (search for "pic programmer" on Instructables).
If you choose to build the Surface Mount Technology (SMT) version, then you'll need:
- A PCB manufacturer to make a double-sided PCB. I used a company called ITEAD who have very reasonable rates and manufacture very high quality boards. All the Gerber files are available on SourceForge. You just need to zip them up and email them to the manufacturer, pay your money and wait.
- To be able to solder small Surface Mount Devices (SMDs) to the PCB. That is not as hard as it seems as the design uses only relatively large SMD parts. There are plenty of tutorials on the Internet showing how to handle SMDs. A Hakko T18-B 1 mm ball tip (or similar) is fine - even for the ICs. Use plenty of "no clean" flux.
- A micro-controller programmer able to program a Microchip PIC18F25K50 micro-controller, such as Mikroelektronika's mikroProg for PIC. Unfortunately the PIC18F25K50 is not supported by Pickit2 and even Pickit3 seems to lack support (well, I couldn't get it to work, so I bought a mikroProg which seems to be better anyway).
And in case it doesn't work for you first time, you may find it helpful to have:
- A good logic analyser like Logic (works on Windows or Linux)
- A USB trace capture program like USBTrace or USBlyzer (for Windows) or Wireshark (free on Linux). On Linux, make sure you're using the libpcap 1.1 (packet capture library) or later.
Circuit Diagram
The circuit can be divided into a number of functional groups.
Infrared Receiver Interface
The infrared receiver consists of the TSOP4838 IR receiver module. Its
job is to convert 38 kHz modulated IR signals from your remote control
into digital ones and zeroes. The receiver will output a logical one
(0V) when the remote is transmitting a 38 kHz signal, and will output a
logical zero (+5V) during periods of silence.
Infrared Transmitter Interface
The transmitter consists of a PN2222A transistor (but any general
purpose NPN transistor will work) which drives a series of three
Infrared Light Emitting Diodes (IR LEDs). Driving three IR LEDs is done
to boost the transmitting power. Learning remotes are designed to accept
signals from remote controls in close proximity and remotes are
designed to produce an intense IR signal. Consequently, IRK! must
produce a fairly intense IR signal in order for the learning remote to
be able to "see" it during the learning process.
LCD Interface
The Liquid Crystal Display is a 2x16 (2 lines at 16 characters per
line) unit compatible with the Hitachi HD44780 4-bit defacto standard.
You can use a 4x16, or a 4x20 display if you like as long as it is
HD44780-compatible. These are available on eBay at very reasonable prices.
USB Interface
The USB interface is provided by the USB module built into the
PIC18F2550 microcontroller. It is managed programmatically by the USB
library provided with the MikroC Pro C Compiler.
Activity LED Interface
Hardly an interface as such - a simple LED and a current-limiting
resistor - but if you use a high intensity (8000 mcd) green LED then
I've found that you can make the resistor an insanely high value - like
about 18 kΩ - and the LED is still bright! That means that the driving
current is only 100 μA. If you use the original 470Ω resistor specified
in the circuit diagram then you could end up being startled by the
brightness.
Power Interface (experimental)
The circuit diagram shows how to power the IRK! unit using the standby
voltage (Vsb) output from your PC's power supply. However, this has not
been tested. You can leave the connection to Vsb out and IRK! will still
work - but if you power down your system, you will not be able to power
it up using your remote control. Just walk over to your PC and turn it
on the old fashioned way!
Programming The Microcontroller
To program the firmware into your IRK unit:
- Download the hex file from SourceForge.The IRK.hex file in the /tht directory is for a PIC18F2550. The IRK.hex file in the /smt directory is for a PIC18F25K50.
- Attach your programmer to the programming header pins on the IRK! circuit board (see picture below).
- Use your PIC programmer to load the hex file into the PIC micro-controller.
For those interested in programming, the source code (of IRK! version 2) on SourceForge is split into two components:
- IRK.c - The main logic which handles infrared transmission, reception, front panel button actions, LCD display, activity LED and communication using USB to the computer.
- USBdsc.c - The USB Human Interface Device (HID) descriptor information which describes the IRK device to the computer when it is plugged in.
How it Works
Overview
The basic idea is that there is a
one-to-one mapping between pressing a button on your remote control and a
key combination sent to your PC. IRK! simply teaches your learning
remote a code that represents a particular key combination. Once you
have programmed that code onto one of your remote buttons, pressing that
button will transmit the code back to IRK! which will, of course,
recognise it then send it to the PC as a USB keystroke.
Because IRK! generated the IR code, it can't possibly not recognise it - so IRK! does not need to support a zillion different IR remote control models!
USB Keystrokes
USB keystrokes are sent to the PC using codes defined in the USB Human Interface Device (HID) Usage Tables
specification. That specification defines, for example, that code 0x04
means the letter "a". For a keyboard device, like IRK!, additional
"modifier" codes can be sent to the PC to indicate whether the GUI (aka
Windows key, Apple key, Super key), Control, Alt and Shift keys are also
"pressed". For example, to send an uppercase "a", IRK! sends 0x02
(meaning Shift is pressed) and 0x04 (meaning "a" is pressed). The
computer interprets that sequence as meaning uppercase "A". Immediately
after sending that sequence, IRK! will send a "null" sequence of 0x00
and 0x00 to indicate that no key or key modifiers are currently being
pressed. This is required by the USB protocol otherwise the PC will
think you are holding down the Shift and "A" keys until it receives the
next USB key code.
So, you can see that IRK! only has to be
able to "teach" a learning remote control a sequence of 0x02 followed by
0x04 to represent the letter "A". When the user presses that button on
the remote, IRK! will receive it using its infrared receiver and then
send the 0x02 0x04 sequence to the PC which will be interpreted as the
user pressing Shift+A on a USB keyboard.
Infrared Command Format
IRK! only recognises infrared signals that are addressed to a
particular IRK! unit. To achieve this, an address byte is also
sent/received on the infrared path. Each infrared command is a sequence
of six (6) bytes as follows:
AA, AA', UX, UX', YY, YY'
Where:
AA is the address byte from 0x00 to 0xFF
AA' is the inverted address byte (all the ones converted to zeroes and vice versa)
UX is the usage page (U = 0x0 to 0xF) and, for the Keyboard usage, modifier nybble X (Control, Alt, Shift)
UX' is the inverted UX byte
YY is the command byte (for Keyboard usage, the USB key code)
YY' is the inverted command byte
The reason for transmitting an inverted copy of each byte is to reduce
the chance that interference has caused an invalid command to be
received. For example, you wouldn't want your request to "play this
recording" to be interpreted as "delete this recording" just because a
fly interrupted the infrared signal path in that instant!
To
validate each command as it is received, IRK! checks that AA (inverted)
equals AA', and that UX (inverted) equals UX', and that YY (inverted)
equals YY', and that either AA equals this IRK!'s device address or AA
equals 0xFF (the broadcast address). If all of the above is true, then
IRK! can be fairly sure that it is a valid command and will act upon it.
Infrared Transmission Technique
IRK! uses Pulse Width Modulation
(PWM) to encode the series of 1's and 0's that constitute each command.
You could reprogram the microcontroller to use a different technique
such as Manchester Encoding but PWM works just fine. For example, the USB '1' key when encoded using PWM looks like the image above.
Whenever the signal is "low", an IR burst of pulses at 38 kHz is being
transmitted. Conversely, when the signal is "high" it represents a
period of silence.
There is a leading burst for 1000 μs then
silence for 600 μs (in versions of IRK! prior to 2.04, it was 9400 μs
and 4500 μs respectively). This leading burst was required by older
infrared receiver modules to "train" their Automatic Gain Control (AGC)
circuits so that they could determine what a normal signal level was.
Today's IR receivers don't usually have this requirement, but your
learning remote may be old so IRK! still supports it.
Thereafter, a '1' is encoded as a short burst followed by a long
silence, and a '0' is encoded as a short burst followed by a short
silence.
Broadcast Address
An address
byte of 0xFF is recognised by all IRK! devices that you may have built.
So it is possible for a single remote control to send a command to ALL
IRK! devices simultaneously.
System Control Commands
IRK! also supports the USB-defined "System Control" commands called
"Sleep", "Wake" and "Power Off". Some USB keyboards have keys for these
functions, but they are not intrinsically keyboard functions. Any
suitably programmed USB device, such as IRK!, can send USB System
Control commands to your PC to request it to go into "Sleep" mode, for
example. The following is a summary of the results of the System Control
commands on my PC (your mileage may vary):
Power Off = CPU off, Disk off, Monitor off, USB off
Sleep = CPU on, Disk off, Monitor off, USB on
Wake = Does not work!
Power Switch Pressed = CPU off, Disk off, Monitor off, USB on
Consumer Device Commands
IRK! supports the USB-defined "Consumer Device" commands such as
"Mute", "Vol+", "Vol-", "Calculator", "Browser Home", You can use these
commands to control your Media Player (play/pause, stop, skip back,
skip forward etc) or start applications (Calculator, Browser, Media
Player etc).
For a complete list of the Consumer Device commands that you can use, just download the USB Human Interface Device Usage Tables
document. That sounds complicated, but the specification is not that
hard to read. Specifically, look at Table 17 "Consumer Usage Page". It
does not matter that IRK! does not display the names of all these
commands as you scroll through them, you can still ask IRK! to send them
to your USB host (e.g. Linux, Windows, MythTV etc) - and the USB host
should execute the corresponding function.
Power Switch and Reset Switch Commands (experimental)
Astute readers will have noticed that there is a problem with trying to
get IRK! to "Power On" your PC - because not all PCs supply power to
USB devices all the time when the system power is off and IRK! depends
on power being provided by the USB interface of the system it is
connected to.
A way around this is to power the IRK! circuitry
from the "Standby" voltage (Vsb) from the PC power supply. Vsb on older
computers supplies +5V at around 10 mA even though you have powered your
PC off. More recent ATX power supplies can deliver Vsb at 2A. This
means that, if powered from Vsb, IRK! can stay awake listening for IR
commands as long as the PC is plugged into the wall power outlet. The
IRK! circuit caters for pressing the Power and Reset buttons on your PC,
but you will have to somehow tap into the Vsb output from your PC's
power supply to get it to work. I don't know of any motherboards that
have a readily accessible header pin for Vsb. This means that if you
want this function, then you may have to physically break the Vsb wire
from the PC power supply. The Vsb wire should be the purple wire.
Note that powering IRK! from Vsb has not been tested at the moment, but
should work in principle. The Power Switch and Reset Switch functions
do work as long as IRK! is powered from USB though.
How to Use It
Using IRK! is easy...all you need to do is:
- Understand the LCD display format of IRK!
- Use IRK! to program your learning remote with each keystroke you want to use
- Use your remote to ask IRK! to send keystrokes to your computer
Understanding The LCD Display Format
The LCD display shows information in the following format for the Keyboard usage:
yy command
Where,
x = The key modifier bits in hexadecimal (e.g. 7 )
modifiers = A textual explanation of the key modifier bits (e.g. CTL ALT SHIFT)
yy = The USB key code in hex (e.g. 2A is Backspace)
command = A textual explanation of the command (e.g. Enter)
...and in the following format for the other usages (Consumer Device, System Control):
yy command
Where,
usage = A textual explanation of the usage code (e.g. Consumer Dev)
yyy = The command code in hex split over two lines (ranging from 000 to FFF, so only 4096 commands are possible)
command = A textual explanation of the command (e.g. Mute)
The following usages (i.e. the "u" in the above) are currently supported:
1 = System Control (Power on, sleep, wake etc)
2 = Consumer Device (Mute, Vol+, Vol-, etc)
F = Local IRK! function
Programming Your Learning Remote
- Connect IRK! to an internal USB header on PC's motherboard. If you have chosen to build IRK! with a standard USB A-B cable, then just plug it into a normal external USB port.
- Wait for IRK! to indicate "USB Ready" on its LCD display. The activity LED will flicker while IRK! is trying to establish USB communications with your PC.
- Using IRK!'s UP, DOWN, CTL, ALT and SHIFT buttons, select a key combination that you want to send to your PC - for example, Ctrl+Home. The CTL, ALT and SHIFT buttons toggle between "pressed" and "not pressed" each time you press them. The CTL button, when pressed for more than 1 second, toggles the GUI indicator. TIP: Press and hold the UP or DOWN buttons to cycle through the available keystrokes quickly.
- Press IRK!'s OK button to send the key combination to your PC to test that it works.
- Set your learning remote to "Learn" mode and select a button to be programmed on your remote.
- Press IRK!'s TEACH button to transmit an IR code representing that key combination to your learning remote.
- Set your learning remote to "Normal" mode and press the newly programmed button on your remote.
- Watch as IRK! sends that key combination to your PC. IRK! will flash the activity LED each time it recognises a keystroke and it will display the last keystroke received on its LCD display.
- Rinse, and repeat from step 3 as many times as you need!
To select a usage other than Keyboard (e.g. Consumer Device):
- Press and hold the SHIFT button for more than 1 second until "Select Usage" is displayed on the LCD
- Press the UP or DOWN buttons until the desired usage is displayed (e.g. Consumer Dev)
- Press OK to use functions in that usage
- Press the UP or DOWN buttons until the desired function is displayed (e.g. Mute)
- Press OK to send the function to your PC to determine if it supports that particular function.
- If the PC responds as expected, press TEACH to program that function onto a button on your learning remote control.
Using Your Remote
This is the same as using any remote. Press a button and IRK! will
respond to commands addressed to it. The most recent command actioned
will be displayed on the LCD. If the Activity LED on the front panel
flashes, then IRK! has recognised the command and has passed it onto the
PC. If nothing happens after that then that's the fault of the PC. If
the Activity LED does NOT flash, then IRK! has not recognised the IR
code programmed onto that button - your IR remote might have a flat
battery, or the maybe the code wasn't programmed accurately, or maybe
you're standing too far away from the IRK! device.
Setting The IRK! Device Address
By default, IRK! will power up using a device address of 0xAA. If you
build more than one IRK! unit, and want to address them individually,
then you will have to set a unique address on each one. An IRK! device
address can be in the range 0x00 to 0xFE (0xFF is the broadcast address
to which all IRK! devices will respond). To do this:
- Press the UP/DOWN buttons until the command "00 Set Address" appears on the LCD display.
- Press OK to enter "Set Address" mode.
- Press the UP/DOWN button until the desired address is displayed in the mm field.
- Press OK to save the new address and exit "Set Address" mode.
From then onwards, that IRK! device will remember the new address in
its on-board non-volatile memory (EEPROM). If you have taught your
learning remote control any commands using the old address, then you may
need to re-program it from the IRK! with the new address.
The following three commands correspond to the USB System Control commands:
- 02 01 Power Off - This will place your PC into system power state S5 (completely powered off)
- 02 02 Sleep - This will place your PC into system power state S3 (suspend to RAM)
- 02 03 Wake - This will wake your PC from S3 and return it to state S0 (powered on)
Experimental Power Control Commands
For the Through Hole Technology (THT) version of IRK!, the following
(non-USB, local to IRK!) commands are experimental (i.e. not fully
tested) and may need the IRK! device to be powered from your PCs standby
voltage (Vsb):
- FF 01 Power Switch - This is equivalent to pressing the POWER button on your PC. The action taken depends on how you have configured your PC
- FF 02 Reset Switch - This is equivalent to pressing the RESET button on your PC. Use this with the same amount of caution that you normally apply when using the real RESET button on your PC! You have been warned.
For
the Surface Mount Technology (SMT) version of IRK!, this list of
commands has been extended and control the operation of the 4066 CMOS
Quad Bilateral Analog Switch:
- F0 01 Power Switch - The
two header pins marked PWR will become low impedance for about 250 ms.
Note: this is not meant to switch large currents. The 4066
quad analog switch can pass an absolute maximum of only +/- 25 mA.
- F0 02 Reset Switch - The two header pins marked RST will become low impedance for about
250 ms.
- F0 03 Init USB - Causes the unit to re-register itself as a USB device. It is
almost the equivalent of unplugging and replugging the device
into a USB port.
- F0 07 Debug on - Displays debug information on the LCD when an IR code is received
- F0 08 Debug off - Returns the unit to Normal mode (displays no debug information on the LCD)
- F0 09 Auxiliary Switch - The two header pins marked AUX will become low impedance for about
250 ms.
- F0 0A Power Switch On - The two header pins marked PWR will become low impedance until a
subsequent Power Switch Off command is received.
- F0 0B Reset Switch On - The two header pins marked RST will become low impedance until a
- F0 0C Auxiliary Switch On - The two header pins marked AUX will become low impedance until a
- F0 0D Power Switch Off - The two header pins marked PWR will become high impedance.
- F0 0E Reset Switch Off - The two header pins marked RST will become high impedance.
- F0 0F Auxiliary Switch Off - The two header pins marked AUX will become high impedance.
Note that although the header pins are labelled PWR, RST and AUX you can use them for any function that would normally use a low current (< 25 mA) Single Pole Single Throw (SPST) momentary action push button switch.
androidarmstrong
