Just received today a PAM8403 based 3W class D filterless amplifier which works at 200~300kHz
A crude test with audio in, 5VSB transformer at output gave a swing of 240V at the oscilloscope... looks promising
I'll have to set up a small valve amp SE stage to proof the project viability, and check optimization at the PAM8403 output stage :)
