Today i tested the system in the field with the new groundstation and FTU. I reached 150 meters with a reasonable video feed. This made me confident and want to jump ahead at setting up an aerial test. I tested using my RC gear right next to the streaming equipment. The transmitter induced a 10 - 20 second delay in the video feed. The RC connection did not seem to be influenced by the streaming equipment.
Te most interesting is that the RC equipment induced a delay, but image quality remained consistent. Increasing the distance of the video feed produced a more intermitted image, but almost no extra delay.
The influence of the RC equipment on the FPV equipment was expected and should be solved in one of the following ways:
- Switch the FPV system to 5Ghz WiFi
- Switch to UHF/LRS RC control
- Control the plane over WiFi
The last one is the most risky but the cheapest
I will investigate the performance of the orangeRx openLRS system and buy it if it is good enough.
Bye!
richardginus
This is not ideal nor final.
