Ok, we've upgraded the pump to a 12v 3.5 Gpm 45 PSI pump, and can squirt water!
This is a pump made to run an RV. So, it sort of puts out water as you might expect from a RV shower or sink. Not house-pressure, but not bad - http://amzn.com/B00KB1HN1C
