Hackaday.io Hackaday.io
Sign up Log in
power inverter - google little box
2kVA DC->AC power inverter
jeffjeff
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3.4k views
7 comments
24 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 7
View Gallery
3.4k
7
24
15
Team (1)
  • jeffjeff
Join this project's team
  • little box challenge
  • github
completed project
hardware
power Inverter Google little-box danger-high-voltage such-small! much-power! STM32 GaN siC
Related lists
Projects using OSHpark boards
projects using the purple PCBs
This project was created on 03/10/2016 and last updated 8 years ago.
Description
2kVA DC->AC power inverter for google little box contest.
did not win.
Project Logs
Collapse
  • github
    jeff • 03/13/2016 at 16:38 • 1 comment
    pushed files to github
  • now that the winner has been announced...
    jeff • 03/10/2016 at 05:23 • 0 comments
    ...I can start sharing
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
Adesuyisunday45 wrote 05/22/2025 at 15:08 • point
This is an interesting project. Jeff please tell us how to build the software code. Is it by Stm32f cube IDE or other software? Tell us so we can fully gain knowledge on the code.If the source code is compiled or built, it’s then we can have the hex or bin to test this project. Kindly tell us the software IDE to use in generating hex file or bin.
tarapwahcantt wrote 10/08/2023 at 21:26 • point
Interested in your project. Could you share the GitHub repository link? I can't find it here. Alternatively, you can message me on my blog for the link. Thanks! https://generatorfirst.com/blogs/
halverurex wrote 04/29/2023 at 13:15 • point
There has been a great deal of value to me in my involvement with the project. Would like to share it with the Prisma team so they can also read it and implement something new.
DaveBoltman wrote 01/07/2022 at 06:47 • point
Looks interesting. Please could you provide a link to your GitHub repository? I don't see it anywhere here on the project site. I'd love to have a look. Thanks!
Gravis wrote 01/08/2022 at 16:42 • point
It's listed on the project page.  Literally just search for the text "github"
DaveBoltman wrote 01/10/2022 at 04:59 • point
Ah, got it. Thanks!
Juan Fco. wrote 01/04/2018 at 16:38 • point
Hello Jeff,
I am really interested in your project because I am designing one too, therefore I have a lot of specific questions for you moreover need some advice from a colleague that have been already through this path. Can you help me out?
Looking forward to hear from you.
Francisco.
I'm converting an Enermax EG465AX-VE(G) into a bench power supply for my hacks.
Project Owner Contributor
ATX power supply conversion for bench usage
christophChristoph
Building a Bench Lab Power Supply using an ATX Power Supply from a PC
ATX Bench Lab Power Supply
orlando-zenOrlando Zen
ws2812b strips in a commercial lighting fixture
OctoLamp
zeldasixactualzeldasixactual
The 2015 Hackaday Prize
The faulty stock Power Supply on the SheevaPlug is replaced with the guts of an equivalent spec wall-wart.
SheevaPlug Revival
leelee
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "power inverter - google little box", please tell us the reason.
Send message
Remove Member
