KORUZA SPECS
1Gbps Version:
ELECTRICAL
- Management port: 100Mbps ethernet + passive PoE
- Data port: 1 Gbps ethernet
- Power supply requirements: 24V (12V-30V) 1A
- Average power consumption: 3W
MECHANICAL
- Outdoor enclosure (material): Painted aluminium
- Mounting: Vertical/horizontal pole up to diameter 60mm
- Weight: Approximately 3.5kg
- Dimensions: 400mm x 100mm x 100mm
- Manual beam alignment accuracy: 1 mrad
- Motorized beam alignment: 0.003 mrad
OPTICAL
- Optical source and detector: SC SFP WDM Bi-Di module with DDM
- Wavelength: Matched pair at 1330 nm/1550 nm
- Transmitter power: 0 dBm
- Receiver sensitivity: -23dBm
- Bandwidth: 1 Gbps
- Laser power: >1mW
- Beam divergence: 0.05 mrad
- Aperture: 50mm NBK7 Plano-convex lens
- Receiver field-of-view: 10 mrad
- Laser class: 1M
- Alignment laser: Green 532nm 5mW
- Alignment laser class: 3B
CONTROL & PROCESSING
- Management microcomputer: Raspberry Pi 2B
- Management interface: http and websocket
- Auto-tracking: under development
- Data processing: none, Layer 1 system
- Annual optical link availability: 99%
ENVIROMENTAL
- Operating temperature: -20 deg C to 60 deg C
- Humidity: undetermined
- Outdoor rating: IP56
- Distance: < 150 m, greater with limited reliability
ATTENUATION @ 100m
- Clear day (10km+ vidibility): 0 dB
- Moderate fog (500m visibility): 1 dB
- Dense fog (100m visibility): 4 dB
- Very dense for (50m visibility): 10 dB
10Gbps Version:
ELECTRICAL
- Data port: SFP cage
MECHANICAL
OPTICAL
- Wavelength: Matched pair at 1270 nm/1310 nm
- Transmitter power: 0.5 dBm
- Receiver sensitivity: -15 dBm
- Bandwidth: 10 Gbps
- Laser power: >1mW
- Laser class: 1M
ENVIROMENTAL
ATTENUATION @ 100m
Musti
smartDIYs
FabLab München
Peter
ganzuul
