Specifications
XYZ CNC MECHANICS
- Cutting area: 900 mm x 900 mm
- Z travel: 150 mm
- Footprint: 1430 mm (W) x 1200mm (L) x 630 mm (H)
- Speed: 1500 mm/min (max)
MOTION SYSTEM
- XY motion system: Timing belt and pulley (T5 or HTD5M or HTD3M)3X Nema 23 stepper motors
- Z motion system: M8 Threaded rod1X Nema 17 stepper motor
CNC CONTROL ELECTRONICS
RAMPS
- OSHW: Yes
- Voltage: 12-24 V
- Driver: Driver-stick A4988 or DRV8825
- Current: 2.5 A
- Firmware: GRBL
- Applications: Basic
ARDUINO + TOSLINK CNC
- OSHW: Yes
- Voltage: 12-36 V
- Driver: PoStep-32, PoStep-256 or THB6600 based driver
- Current: 5 A
- Firmware: GRBL
- Applications: Default
PLANET CNC + TOSLINK CNC
- OSHW: No
- Voltage: 12-48 V
- Current: 5 A
- Firmware: PLANET CNC
- Applications: Pro
MACHINING
MILL
- Material: Most materials
- Tool: Spindle
- Speed: 1000 mm/s (for 3mm birch wood with 3mm mill)
PLASMA
- Material: Metal
- Tool: Plasma torch
- Speed: 1000 mm/s (for 3mm black steel)
- Additionally required: Air compressor (30-100 l/min at 2-4 bar -effective 180 l/min)
LASER
- Material: Wood and plastic
- Tool: Diode or CO2 Laser
- Speed: Depends on material
- Additionally required: Air compressor, water cooling
Musti
notme
Dmitry Shevchenko
MasterOfNull
