Specifications
- Base price: 990 EUR for full KIT (available from Fabrikor)
PRINTING SPECIFICATIONS
- Build volume (mm): 300 X 300 X 300
- Auto levelling: Optional
- Minimal layer height (mm): 0.05
- Steps/mm (X & Y): 80
- HotEnd: 1 X E3D-V6 1.75 mm (swappable with any E3D)
- Travel speed (mm/s): 200
- Print speed (mm/s): 150
- Heated bed: Yes - 24V or 230V
MECHANICAL SPECIFICATIONS
- Desktop size (mm): 460 X 440 X 660
- Frame: Plywood
- Linear rails: 8 mm ground hardened steel
ELECTRICAL SPECIFICATIONS
- Supply Voltage (V AC): 240 or 110
- Supply connection: Switched and fused IEC Socket. Lead not provided.
- Power supply: 1 X 24V 100W / 1 X 24V 350W (if 24V bed)
- Electronics control board: RUMBA + LCD
- Motor drivers: 4 X DRV8825 (X,Y,Z,E)
- Motors: X: 46 Ncm 1.8° / Y: 46 Ncm 1.8° / Z: 46 Ncm 1.8°
SOFTWARE SPECIFICATIONS
- Recommended slicing software: CURA / Slic3r
BUILD TIME
- From full-kit: 12h
Musti
Dmitry Shevchenko
pcadic
Valera Perinski
Nutty Gear Studio
