I spent some time cleaning up the schematic — fixing the custom part graphics, adding net labels and arranging it in a way that hopefully makes it a bit easier to read. In the proces I noticed that I didn't connect the ground of the buttons on the right side to the ground — another bodge wire needed. Also, all the values for resistors and capacitors are still wrong — I will need to change them.
I also put all the design files and code into a repository, for everybody to enjoy. Please be aware that it is still work in progress and that there most likely will be changes.
