While the PCB is ordered (thank you again @oshpark!), I decided that I can actually prototype using a Feather M0 and a prototyping shield that I made specially for this kind of tasks. I had to remove the header I already soldered to the LCD module, and since I was afraid to use hot air so close to the display, I had to do it the old-fashioned, rough way, and in the process stripped two of the pads. Fortunately they are find on the other side, which is also where they are connected, so everything still works. When the PCB comes, I will remove the display from that module anyways.
This is the display filled all black, without the backlight.
I quickly wrote a simple driver library for CircuitPython for handling the display. It uses almost the same commands as all the OLEDs out there. I didn't provide a "pixel" method, since you will be blitting whole bitmaps on it anyways.
class Display:
_byte = bytearray(1)
_word = bytearray(2)
width = 128
height = 64
def __init__(self, spi, dc):
self._spi = spi
self._dc = dc
pages = self.height // 8
self.buffer = bytearray(self.width * pages)
self._view = memoryview(self.buffer)
self._move = bytearray(b'\xb0\x04\x10')
self.reset()
self.mirror(0)
self.active(1)
def _command(self, data):
self._dc.value = 0
self._spi.write(data)
def reset(self):
self._command(b'\xe2\x2f')
def active(self, val):
self._command(b'\xaf' if val else b'\xae')
def inverse(self, val):
self._command(b'\xa7' if val else b'\xa6')
def vscroll(self, dy):
self._byte[0] = 0x40 | dy & 0x3f
self._command(self._byte)
def flip(self, val):
self._command(b'\xc0' if val else b'\xc8')
def mirror(self, val):
self._command(b'\xa0' if val else b'\xa1')
self._move[1] = 0 if val else 4
def contrast(self, val):
self._word[0] = 0x81
self._word[1] = val & 0xff
self._command(self._word)
def update(self):
index = 0
for page in range(self.height // 8):
self._move[0] = 0xb0 | page
self.value = 0
self._spi.write(self._move)
self._dc.value = 1
self._spi.write(self._view[index:index + self.width])
index += self.width
Next, I need an image class and a code for doing the blits with a mask. I might do the same optimization as I did for the #Micro:Boy and keep track of what parts of the display pages need updating — but at 40MHz SPI I don't really think it will be necessary.
deʃhipu
