Led Pixels as wall decoration in a Pub
600 animated LED pixels as wall decoration for an industrial-feel cocktail bar - done with Arduino and WS2801 pixels
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
We have made a wall decoration in a pub called "The Soviet", a Russian themed cocktail bar in Cluj-Napoca with an industrial feel from the USSR days. The pixels were wrapped around old movie reels giving them a discreet glow-effect. We then animated the pixels to give the appearance of the reels turning.
The challenge was in powering these puppies. We have accidentally purchased 5V LED strips drawing a combined 30 Amps (~150Watts) of power (when turned to full white / max brightness). We have ended up individually powering strips of 30 cm, because if we were to put the whole 30 amps on the whole 10 meter of strips - even if both ends were connected - the LEDs on each end would wear out and loose colour in about a couple of days.
The power source is a modified ATX power supply that really does the job well.
Youtube: https://www.youtube.com/watch?v=IQ3vLXnOmeE
