UPDATE 19 MARCH 2016
Got my U.FL to RP-SMA pigtails with antennas. I have a few nice black cases by OneNineDesign that came with Rapsberry Pi 2 kits by CanaKit. I modified one for the Pi3 plus pigtail & external antenna.
I cut a little notch in the plastic for the wire to come up from underside the board, hollowed the Pi2 LED holes to pass the cable thru, then drilled a hole above the power connector to mount the SMA connector.
Then finally I mis-measured & ended up with a terrible hole for the Pi3 LEDs to shine thru. :P
See additional link to Google Photos album called Case Modification.
-KJ
ORIGINAL:
With my Fluke multimeter I checked continuity from the radio antenna output thru the two tiny zero-ohm resistors, all the way to the metallic looking parts of the onboard antenna chip. I got beeps all the way.
I checked continuity from the radio antenna output to the little gold square where the U.FL center pin contact might go - nada, open.
Alright, time to potentially ruin my brand new Pi 3!
I imaged an SD card with Raspbian Jessie Lite, setup everything to my preferences, and installed wavemon. After each step of abusing my Pi 3's circuit board, I let it cool, inserted the SD card & powered up, SSH'd in, checked wavemon, then took photos.
I have linked to my Google Photos album so you can see all the pics I took. For the pics I've uploaded to this project, I used Skitch to screenshot & markup with the arrows and text.
There is ground plane on the opposite side of the exposed J13 rectangular pad, so I scraped off some solder mask, then I tinned up all three spots.
I took a wifi module out of a junk laptop then with my heat gun and tweezers I lifted both U.FL connectors from it.
Heat gun and tweezers again, I placed the U.FL connector on J13.
I snapped on an antenna lead I pulled out of the same junk laptop - oops, when it swivels it will short the Pi3's ground plane to GPIO pin 1 - 3.3Vdc. I mixed up a little bit of non-conductive epoxy and put a blob over that pin to insulate it - problem solved.
I put a tiny piece of solder at the radio's antenna output & the dot where the U.FL square pad trace comes up, melted it with the heat gun. Check continuity again with the meter - YAY! Got continuity with both the onboard antenna chip and the U.FL center pin.
I booted it up and ran wavemon to check signal strengths with & without the laptop antenna lead connected, not much difference.
So now everything still works, time to go all in! I fired up the heat gun again, with a needle pick I flicked away the zero ohm resistors (I have no clue where they went, so tiny!) that run along the little J-shaped trace thru the via to the onboard antenna.
I checked continuity again - onboard antenna nada, U.FL center pin game on!
Finally I booted up without the laptop antenna lead. I was able to SSH in and run wavemon, my signal strength to the AP 10 feet away was -66 dBm, and my neighbors didn't even show up on F3-scan. I snapped on the laptop antenna lead, and BLAM! My wifi was -29 dBm, and the neighbors showed up in wavemon as I expected.
With this modification a Pi3 can easily mount inside a metal enclosure. My omni antennas with U.FL to RP-SMA pigtails will arrive tomorrow. =)
Andrew Mitz
YC-L
ajlitt
James Fossey
AWESOME Article !!!
Thank you SOOOO MUCH !!!!
This is what hackaday is all about, sharing good knowledge and great ingenuity from the general public helping others to get their existing tech made better - well done Sir !!!
