Paper feed considerations
A project log for Direct UV Printer for Alternative Photography
Design of a UV printer for making exposures of Alternative Photography prints, direct from a digital image
david-brownDavid Brown 03/17/2016 at 20:460 Comments
In reviewing the paper feed methodology I've identified 3 possible options for passing the paper through the printer. I've come to the conclusion that a caddy / board based system where the paper is affixed to a board that is then passed through the printer is the most robust and lowest risk option.
Tabbed paper feeder - similar to dot matrix
Pros;
Cons;
As the process requires special paper this method is not viable solution
Roller feeder - similar to traditional printer
Pros;
Cons;
A high risk options that can be foreseen to cause many headaches in its setup, and may prove unusable.
Board/Caddy feeder - similar to CD printer
Pros;
Cons;
Selected option, more space required, but most robust and practicable option at this stage.
