TEC controller - populating
A project log for Direct UV Printer for Alternative Photography
Design of a UV printer for making exposures of Alternative Photography prints, direct from a digital image
david-brownDavid Brown 04/05/2016 at 01:020 Comments
Populated the majority of the TEC controller board, still waiting on an op-amp that is on back order, but I should be able to test the DAC that controls the temperature set point. Very pleased with this board even if the circuit is 98% the one for the evaluation kit, the layout is 100% my own. Will find out in due course if it works.
