RPi Zero breakout board
A project log for Direct UV Printer for Alternative Photography
Design of a UV printer for making exposures of Alternative Photography prints, direct from a digital image
david-brownDavid Brown 03/12/2016 at 00:030 Comments
The printers brain will be a Raspberry Pi Zero computer, with a servant Arduino in the printer head itself to provide flexible monitoring and control functions on the fly. Initial calibration and static settings will be set at system startup (using MCP23017 s to set DACs, frequency generator, etc.) so wont require resources during the printing process.
This update is for the breakout board to allow the Raspberry Pi Zero to;
The following Eagle CAD layout of the breakout board, shows the rPiZero and EasyDriver units with the x3 voltage level converters.
3D CAD model to check assembly below. POGO pins used to connect out the USB from the test pads on the underside of the rPiZero. nylon stand-offs will be used to secure the boards.
