Clocking out FIFO & fake parts
A project log for Direct UV Printer for Alternative Photography
Design of a UV printer for making exposures of Alternative Photography prints, direct from a digital image
david-brownDavid Brown 04/06/2016 at 21:203 Comments
For the current laser power I need a clock out frequency of 2MHz, but i've run a test using TINA simulation software at 10MHz, the transient analysis look reasonable (to my untrained eyes.
I've also been running some test on the write out speed from the raspberry pi, which is looking reasonable through the 600mm ribbon cable. I need a data rate of 500kHz (2us) pulse width.
In other news the IDT FIFO chips i bought off ebay appear to be fakes, they appear to work, but response speed is dire and they are missing the IDT logo, which should have been a big red flag, but I bought them right at the beginning, so another learning experience.
[Followup - ran a full test on the dodgy chips, write depth of 8192 matches but the read out flag is non-responsive, they have also been over-coated, see here for many good examples; Components Technology Institute counterfit examples]
Rich text editor
Yann Guidon / YGDES wrote 04/07/2016 at 00:17 point
What kind of FIFO do you need ?
David Brown wrote 04/07/2016 at 02:43 point
I've been designing around the IDT 720 series, 9bit FIFOs, fake part was marked 7205L15J but mouser has the 7203L12JG which has sufficient depth for ~$10 so i'll probably go with that.
Yann Guidon / YGDES wrote 04/07/2016 at 03:14 point
If you found a suitable reference, fine, I have pulls and samples for a variety of characteristics otherwise. Oh and some more of these for good measure:
http://www.ebay.com/itm/20-ST-MK45H03K-FIFO-512x9-80ns-5V-EMPTY-FULL-FLAGS-EXPANDABLE-PLCC-32-SMD-SMT-/271857152435
