I2C interface is quite useful for extension of small MCU, because it just consume two pins (CLK and DAT). The case of Attiny10, it does not support by its hardware but indeed more than five years ago, some people and guys succeeded to implemented in C. For me, assembly seems to be more straightforward and I made the code from scratch.
Actually bitbang is a kind of "very fast LED blinking". If you can make LED blink program in some MCU, you will be able to implement I2C on it. For implementing it, for example, bit "1" and "0" coding is like this:
bit_high:
ldi temp1, 0b00
out PORTB, temp1
rcall delay
ldi temp1, 0b01
out PORTB, temp1
rcall delay
ldi temp1, 0b11
out PORTB, temp1
rcall delay
ldi temp1, 0b01
out PORTB, temp1
rcall delay
ldi temp1, 0b00
out PORTB, temp1
rcall delay
ret
;cl=1 da=0
bit_low:
ldi temp1, 0b00
out PORTB, temp1
rcall delay
ldi temp1, 0b00
out PORTB, temp1
rcall delay
ldi temp1, 0b10
out PORTB, temp1
rcall delay
ldi temp1, 0b00
out PORTB, temp1
rcall delay
ldi temp1, 0b00
out PORTB, temp1
rcall delay
ret
Here PB0 is SDA and PB1 is SCL of I2C. It is LED blinking, isn't it? If you have logic analyser (not expensive one but just a handy USB based analyser, in my case...) , actual timing and logic level can be confirmed and quite useful for completing bitbang.
Segment Begin End Code Data Used Size Use%
[.cseg] 0x000000 0x0001e6 486 0 486 1024
[.dseg] 0x000040 0x000060 0 0 0 32
[.eseg] 0x000000 0x000000 0 0 0 0
Just 48% of flash and zero SRAM consumption yet (everything is processed in registers). My code (I am so sorry but it is quite dirty and redundant and no-sophisticted) is released on github, again it is combination of "LED blinking".Actual operation can be found in the following movie.. have fun!
Hello, It is ST7032 based LCD, which can be found... for example, http://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20160625052224&SearchText=0802+i2c
The LCD looks sweet. Where did you get this one?
