As I presented in the previous log, I2C supporting in ATtiny10 seems to be successful. This time I activate A/D converter of ATtiny10. Indeed, ATtiny10 supporting I2C LCD and A/D leads to super simple Voltage meter!!
Segment Begin End Code Data Used Size Use%
[.cseg] 0x000000 0x00038c 908 0 908 1024
[.dseg] 0x000040 0x000060 0 0 0 32
[.eseg] 0x000000 0x000000 0 0 0 0
it can be still inside internal flash of ATtiny10.My dirty assembly code is released on github and actual operation can be found in the following movie. Indeed response is well acceptable for voltage measurement application (main concern is accuracy, though...) Anyway, have fun!
