I just added one switch, which changes LED blinking interval by the following source...
.def R_TEMP1 =R17
.def R_TEMP2 =R18
.def R_TEMP3 =R19
.def R_TEMP4 =R20
.def sw_cond =R21
.equ led_p = 3
.equ sw_in = 4
.equ SUB_COUNT = 8
RJMP MAIN
MAIN:
LDI R_TEMP1, 4 ; prescaler of timer0 setting
OUT TCCR0B, R_TEMP1; clock of CPU divided by 5= 1024,4=256,3=64
; real frequency of blink will be (MPU clock)/256/precsaler value
LDI R_TEMP1, 1<<PUD
OUT MCUCR, R_TEMP1
LDI R_TEMP1, (1<<led_p) ;seting PORTB for output
OUT DDRB, R_TEMP1;seting led_p for output
LDI R_TEMP2, (1<<led_p)|(1<<sw_in);led_p=PB3 on, sw_in=pullup
OUT PORTB, R_TEMP2
LOOPPOINT:
SBI PINB, led_p; flip led on and off
IN R_TEMP3, PINB ; reading state of portb
ANDI R_TEMP3, (1<<sw_in) ; checking sw status
BRNE ANOTHER; if sw_in not equal 1, jump to ANOTHER
LDI sw_cond, 0; putting sw_cond to zero if sw_in is zero
RJMP POINT
ANOTHER:
LDI sw_cond, 1; putting sw_cond to 1 if sw_in is one
POINT:
RCALL DELAY2
SBI PINB, led_p ; flip led on and off
RCALL DELAY2; calling subroutine delay
RJMP LOOPPOINT ;jump to LOOPPOINT
DELAY2: ; subroutine DELAY
LDI R_TEMP4, 1
ANDI sw_cond, 1 ; checking current sw condition
BRNE COUNTER2 ; if switch is zero, jump to COUNTER2
LDI R_TEMP4, SUB_COUNT
COUNTER2:
IN R_TEMP1, TIFR0; loading current state (TIFR0) of TIMER0
ANDI R_TEMP1, 1<<TOV0; checking overflow flag TOV0
BREQ COUNTER2 ; if counter is not overflow, jump to COUNTER2
LDI R_TEMP1, 1<<TOV0 ; writing 1 to TOV0 leads to reset of TIMER0
OUT TIFR0, R_TEMP1
LDI R_TEMP3, 1
SUB R_TEMP4, R_TEMP3 ; decrease 1 to SUB_COUNT number
BRNE COUNTER2 ; if count by sub_count is finished, ret,else to counter2
RET
This source provides 227 bytes .hex file. Still I have much room for programming on ATtiny13..
