And I am trying even more smaller MCU, ATtiny 10, actually its size is identical to general switching transistor. But even in such a small package, it has 4ch 8bit A/D converter with 1024 words flash memory. 6pin is not enough to support full SPI writing but there is a special way, TPI (details can be found in websites) but we don't need to worry about TPI. ATmel Studio with Atmel ICE fully supports its programming.
Here is actual prototype board putting ATtiny10 for 6-pin dip break out. On the surface....
This is a actual wiring information between ATtiny10 and ATmel ICE. MOSI has no connection but binary transfer is supported by Atmel Studio.
The following simple assembly code enables tiny voltage indicator...
.def r_temp1 = R16
.def r_temp2 = R17
.def r_temp3 = R18
.equ lv_1 = 0x40 ; values for voltage comparison
.equ lv_2 = 0x80
.equ lv_3 = 0xC0
setup:
ldi r_temp1, ((1<<ADEN)+(1<<ADSC)+(1<<ADATE)+(1<<ADIE)+(0<<ADIF)+(1<<ADPS2)+(1<<ADPS1)+(1<<ADPS2))
out ADCSRA,r_temp1
;starting A/D conversion (free running mode)
ldi r_temp1, ((1<<MUX1)+(0<<MUX0)) ; input A/D = PB2
out ADMUX,r_temp1
; setting PB2 for A/D input
ldi r_temp1, ((0<<DDB2)+(1<<DDB1)+(1<<DDB0))
; PB0 and 1 are LED out
out DDRB, r_temp1
; PB0, 1 for LED output (PB2 for input)
main: ; main loop start!
in r_temp1,ADCL
;reading lower bit of A/D result
cpi r_temp1, lv_1 ; comparing measured result with lv_1=0x2b
brlo s_vchk_1 ; if the measured value is lower than 0x40, jump to s_vchk_10
cpi r_temp1, lv_2 ; comparing measured result with lv_2=0x80
brlo s_vchk_2
cpi r_temp1, lv_3 ; comparing measured result with lv_3=0xC0
brlo s_vchk_3
rjmp main ; closing main loop
s_vchk_1:
ldi r_temp3, 0x00 ;all LED are off (positive logic)
out PORTB, r_temp3
ret ; return to main loop
s_vchk_2:
ldi r_temp3, 0b00001 ;PB0 is on
out PORTB, r_temp3
s_vchk_3:
ldi r_temp3, 0b00011 ; PB0, 1 are on
out PORTB, r_temp3
"ATtiny10" memory use summary [bytes]:
Segment Begin End Code Data Used Size Use%
[.cseg] 0x000000 0x00002e 46 0 46 1024 4.5%
[.dseg] 0x000040 0x000060 0 0 0 32 0.0%
[.eseg] 0x000000 0x000000 0 0 0 0 -
Assembly complete, 0 errors. 0 warningsAccording to Atmel Studio, Attiny10 is well enough to accommodate my short code and still has lots of room! (Seems just 4.5% of capacity is using...)Actual operation can be found in the following movie... have fun!
microwavemont
