I think it is quite close to "ultimate" application of tiny ATtiny10. Eventually two applications, frequency counter and digital volt meter is combined in just one code and its function can be switched by pushing switch ON or OFF as initial condition.
And my assembly code eventually ( already released at github) approaches to the limit of ATtiny10, 1024 bytes (1 kB)....
Segment Begin End Code Data Used Size Use%
[.cseg] 0x000000 0x0003ae 942 0 942 1024 92.0%
[.dseg] 0x000040 0x000060 0 0 0 32 0.0%
[.eseg] 0x000000 0x000000 0 0 0 0 -
Again it is dirty and not well organised but surely working as multi-function instrument. Actual operation can be found in the following movie... Have fun!!
