Most of my earlier timing diagrams were higher-level than reality... so I've been working on lower-level timing-diagrams. My energy's fading, so it's not yet complete... nor is what's there 100% verified (e.g. the number of clock-cycles between the one-shot signals' *inputs* and their outputs...)
Here's the simplified diagram I worked with to code this thing up...
Key points:
- DQM must mask the data at the Command/Address DQ's for several reasons:
- At the start, there may be a burst-read in progress already or other previous operation which might interfere with loading the Command/Address in step 2
- As soon as the (first) burst-read begins, data output would definitely collide with the Command/Address still remaining on those pins as we wait to switch those (host's) pins to inputs
- Load the "Read-Burst" command (and the associated column address) to the associated Command/Address pins.
- Activate /CS changing the INHIBITED "Read-Burst" command into an *actual* "Read-Burst" command
- The data is available 3 clock-cycles later (CAS-Latency=3), but will remain masked, until we have a chance to change the Command/Address pins to inputs
- Until the next step, the Burst-Read will be repeated numerous times from the same starting-address. Each previous burst will be truncated by the next.
- Disable CKE
- The "Read-Burst" command, with /CS active, will be recognized *one* more time, alongside the first clock-edge where CKE is read LOW.
- From there-on, the "Read-Burst" command, and /CS's being active will be ignored, so disable /CS whenever ready
- The last-initiated burst-read will be immediately paused
- Switch the Command/Address host-pins from outputs to inputs
- Unmask the read-burst data-output to be read on the host's Command/Address pins
- DQM has a latency of two clocks during read-bursts, so we'll need two CKE strobes
- (Guess we lucked-out that step 4 allows for starting *one* more read-burst, because these two CKE strobes will result in output from the requested column (column 0) rather than one or two thereafter!)
- Strobe CKE Twice (each strobe must be no longer than one SDRAM-clock-period!)
- Skip ahead to B:
- Remask the data-output from the read-burst
- Reenable CKE
- Two clock-cycles later, the read-burst will be masked
- Switch the Command/Address host-pins back to outputs, in preparation for the next operation
- The (masked) read-burst will continue indefinitely, since it's set to burst a full page and wrap when complete... I issue a PRECHARGE command as the next operation.
Having the timing-diagram *alongside* the circuit seems to help to make things clearer.
And here it is in a bit more detail... taking into account the one-shot circuitry and the associated bypass/override signals (which may be poorly-named).
void sdramFR_readACD(uint8_t bank, uint16_t row, uint16_t column,
uint8_t *dBank, uint16_t *dAddr, uint8_t *dCmd, uint16_t count)
//Assuming the Command/Addr IOs are currently outputs:
//Mask the data-bits so they don't write to the C/A IOs while they're
//outputs...
//(Is this not part of the above assumption?)
sdram_disableAllBytes(); //1
//Activate the selected row on the selected bank
sdram_activateRow(SDRAM_FR_DEVNUM, row, bank);
//Prepare a read-burst (masked) starting at the selected column
sdram_setupAddress(column - READ_COL_OFFSET, bank); //2
sdram_setupCommand(SDRAM_CMD__READ); //2
//The read-burst command will execute immediately after this
// BUT, it will be repeated/restarted with each clock-cycle
// UNTIL the clock-cycle AFTER CKE is disabled.
sdramFR_overrideCS_OneShot(); //3
sdram_clockDisable(); //4
sdramFR_enableCKE_OneShot(); //4i
// /CS is still active
// Only the first, AFTER clockDisable, will be registered
sdramFR_unoverrideCS_OneShot(); //4a
//Set the fed-back Address/Command pins as inputs
// (Also takes care of Free-Runner's nCS_DQ
sdramFR_AddrCmdIO_AsInputs(); //5
//Unmask the data-bits (will occur somewhere down the line)
// Should be exactly two CKE-strobes later, right?
clrpinPORT(SDRAM_FR_DQM_PIN, SDRAM_DQM_PORT); //6
//Assuming a CAS-Latency of 3...
//(Right, two are necessary, otherwise still in CASL
// read-back floating bus from last col-assignment TESTED TRUE)
// OR: was that due to DQM-Latency?
sdram_strobeClockEnable(); //7,8
//Mightaswell take advantage of the ol' bursts!
while(count>0)
sdram_strobeClockEnable(); //9,A
//Note that the strobe is delayed a couple SDRAM clock-cycles
delay();
//Now there should be data on the ports...
//Read Back ADDRL
uint8_t addrLval = PIN_FROM_PORT(SDRAM_ADDRL_PORT);
//ASSUMING ADDRH and BA are on the same port... (BA = bits 6,7)
uint8_t addrH_BA_val = PIN_FROM_PORT(SDRAM_ADDRH_PORT);
if(dAddr != NULL)
*dAddr = (uint16_t)addrLval
| (uint16_t)((addrH_BA_val & SDRAM_ADDRH_MASK) << 8);
dAddr++;
if(dBank != NULL)
*dBank = (addrH_BA_val >> SDRAM_BANKADDR_SHIFT);
dBank++;
//And tack-on the Free-Runner's fed-back Chip-Select
//Actually, for now, this is all properly-aligned, so just change the
//MASK, above...
if(dCmd != NULL)
*dCmd = PIN_FROM_PORT(SDRAM_FR__CMD_DQ_PORT) & SDRAM_FR__CMD_DQ_MASK;
dCmd++;
count--;
//Mask the data-bits so we can take back the C/A IOs as outputs
sdram_disableAllBytes(); //B
//But that won't be registered until the clock's enabled...
sdramFR_bypassCKE_OneShot(); //C
sdram_clockEnable(); //D
//And there's a slight DQM-latency, right...?
delay();
//Now take back the Address/Command pins as outputs
// (Leaving it in a known state)
sdramFR_AddrCmdIO_AsOutputs();
//Let's do a precharge-all just so we know where we're at...
sdram_precharge(SDRAM_FR_DEVNUM, PRECHARGE_ALL);
It's, really, quite a bit of work to read/write data to the DQ's which are fed-back directly to the Address/Command pins. A *much* easier method, of course, would be to insert buffers (with output-enables) between the DQs and the Address/Command pins. But, this would also require an additional 19(?) I/Os from the host... nothing to scoff at. Then again, it would be *significantly* more intuitive, so there's that.
That "more-intuitive" system is, pretty much, what sdramThing1.0 was going for, but I ran out of I/Os (and was a bit too lazy, anyhow) to solder up DQ's for all 13 address-lines. Instead, sdramThing1.0 merely fed-back the *command* signals, and the AVR was responsible for iterating through the addresses (which only had to happen at 3/1024ths of the SDRAM-clock rate, for Precharge, Activate, and Read commands for each 1024-column page). Instead of using buffers with output-enables, I inserted resistors (much as I plan to do to whittle down the 32bits on the side-kick down to 8bits, and plausibly also for getting away with one-directional latches (such as the 74374/574) for bidirectional data-flow. For sdramThing1.0 speeds were slowed *dramatically* by, I'm pretty sure, those resistors... but if you look at them closely, I'm almost certain I accidentally used *wire-wound*. Whoops. At those speeds they weren't resistors as much as inductors. A similar set-up with a fedback-path via resistor is seen in the schematic above, where a 390 ohm resistor ties /CS_DQ -> CS_OS_OVRD, and currently runs fine at 22.3MHz.
On The Other Hand.... Maybe I've gotten a bit carried away with trying to make full advantage of the least amount of external support circuitry (and I/Os)... Because... it's something like 16 steps just to start a Read, similar for a Write... Without making extensive use of the burst-nature, that would *DRAMATICALLY* slow-down writing of the free-runner stuff... Ah, right, but that's only during boot, which is bordering on 3 minutes with a 16MHz processor (and, remember, 50MHz toggle-rates from a PI's GPIOs is pushing its limits)... Does boot-time really matter enough to justify at least 3 D-latches and 3 Buffers...? (or maybe resistor-networks)?
Alright, the address-jumping method mentioned previously... that'd be necessary for *all* reads/writes (including reading back of the sampled data), so that'd be a limiter *when using* the system, whereas this is only a limiter *when booting*.
