Here you can see the 2 changes i made to version one to use it, a 100nF ceramic capacitor between 328 vcc/gnd to smooth power ripple, and a new entry hole for the wider magnetic reed switch i was supplied.
A project log for Single Layer Through Hole Arduino 328 & NRF24 PCB
Minimal, Long Range, Low Voltage, Long Life, with switchable RF Vcc
