Switching from Microchip to TI
A project log for CM3 Board + Backend-Library + Bee Hive Monitor
An open solution enabling everone to build and maintain a IoT enabled sensor network. BeeStalker is the reference for you project!
johannwilhelmjohann.wilhelm 03/23/2016 at 16:340 Comments
So, I did some more research and the TPS61232 will get my new booster to power the RPi from my single LiPo-Cell.
Check out the specs! 2.1A@5V with 3.3V in kind of overkill but also allows the use of a RPi3!
The order has been placed at Farnell, so at the weeked I should be able to do some tests...
73
