The initial script-set now works.
A new SD-Card image will come the next days!
Btw. There's no a avrdude-6.3 repo on gogs.9mal6.de which has the linuxspi patch... some changes were needed here to make it work.
73
A project log for CM3 Board + Backend-Library + Bee Hive Monitor
An open solution enabling everone to build and maintain a IoT enabled sensor network. BeeStalker is the reference for you project!
73
