I wanted to send PCB in production, but i have a problem with the gerber files of the harvesting module : The online gerber viewer (from JLCPCB) does not want it.
There is no problem with the other two modules, and i use the same export parameters.
I tried to export with another computer (and a different OS), but the problem persists.
I also tried to upload the files to another PCB manufacturer (EuroCircuit: we use this manufacturer at my job, but it's a lot more expensive than the Chinese manufacturer), and it works this time...
I don't understand where the problem come from...
I have to look at this more closely (waiting for the results of the robotic contest).
