I miss typed the forming temperature. It should be 375 degrees. This link provides excellent information for perfecting the process -- http://www.plexiglas.com/export/sites/plexiglas/.content/medias/downloads/sheet-docs/plexiglas-forming-manual.pdf
Pressure form Plexiglas for exterior lighting on an experimental aircraft. Could also vacuum form.
