We all know static build up in clouds is pretty powerful, but we haven't really found a way to harness this power. Lightning rods work by harmlessly discharging the atmospheric electricity (and occasionally lightning) into the ground. I propose we add an electrolysis rig (sitting in water) to a lightning rod to turn some of this electricity into browns gas, which can be used to run a plethora of things such as a backup generator, small engines, or just a heater warm up the place. Since all of this runs off of browns gas, the only exhaust will be water vapor.
Terry Daniels
jason.gullickson
jeremy.geppert
Jake
Compressing Brown's gas for storage would not be even remotely safe. There was a write-up about a Florida explosion that involved someone compressing a similar mixture with the intent of selling it to restaurants.
Edit: Found the article:
http://www.fireengineering.com/articles/print/volume-167/issue-11/features/the-dangers-of-hydrogen-based-experimental-fuels-p1.html
