Fluid retention, of the portal kind.
A project log for Interdimensional Portal Gun
A 3D printed portal gun, which projects animated portals.
masterofnullMasterOfNull 04/10/2018 at 18:020 Comments
Made a two part retainer for the portal fluid container.  It fits inside the lip left when you cut the top off the baby bottle, and bolts through the body.
So... I've made enough changes that I'm reprinting everything.
I've worn out my last .4mm nozzle.  The prints were getting pretty sloppy looking when I did the handle print, so that leaves pretty much every other size from 1.0mm to 0.1mm in my supply bin.  I mainly use 0.4mm.
I went with 0.3mm and changed the <nozzle_dia> in my source so my wall thicknesses are all exact multiples of this, re-rendered, re-sliced, and I'm re-printing.  Slowly...
About 10 hours into the first 17 hour print.
Patience Daniel son...
