A while back I changed the ring gears from directly interfacing to interfacing with an idler gear.
This fit the form factor better, but I just realized this also makes it so I now no longer have counter-rotating discs. They all rotate the same direction now. Oops.
![](https://cdn.hackaday.io/images/2140201555955309420.png)
At least one of the images needs to rotate in the other direction to allow the optical illusion of radial motion to work, I think...
I still have different rotation rates between the images, so in a sense they are rotating in opposite directions. Will it be enough to generate the radial motion illusion? I don't know. I may need to go back to the previous gearing. We'll see.
